MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/16GB Dual WiFi Fast Lan BT4.1
Just updated to OTA 20170801 and the boot animation and music have been removed. The label "MBOX make your life color"has been added. A new application DRM check is also added to this build. BCenter and MgmtSupport have been brought back again..
No any trace of Youtube icon in the application list.
Originally posted by Capitolhill View PostMagendanz could you please check this latest file. TWRP reports an error and appears to be for another box. Looks like 212 file. I've been checking and for some reason there are M8S pro boxes but are 905 and 905x platforms both by MeCool. Strange!! Comments
I:Looking for zip at '/external_sd/M8S_PRO-ota-20170801.150811.V0321.zip'
Installing zip file '/external_sd/M8S_PRO-ota-20170801.150811.V0321.zip'
Checking for Digest file...
Skipping Digest check: no Digest file found
I:Update binary zip
I:Zip does not contain SELinux file_contexts file in its root.
I:Legacy property environment initialized.
script aborted: E3004: This package is for "M8SPRO" devices; this is a "q20x".
error: 3004
Updater process ended with ERROR: 7
I:Legacy property environment disabled.
I:Install took 0 second(s).
Error installing zip file '/external_sd/M8S_PRO-ota-20170801.150811.V0321.zip'
Done processing script file
The OTA does work throgh the Update app if you choose "Local Update" and select the M8S_PRO-ota-20170801.150811.V0321.zip
Originally posted by SFA View PostJust updated to OTA 20170801 and the boot animation and music have been removed. The label "MBOX make your life color"has been added. A new application DRM check is also added to this build. BCenter and MgmtSupport have been brought back again..
It has also introduced the problems that I am seeing with the 5Ghz Radio droping the wifi connection randomly which was present in the 20170524 build, but was fixed in the 20170707 Build...
I'm sticking with the 20170707 for now, until Guest has time to update his Stock Nexus or Nano ROM's to be based on 20170707 or a build with a fixed 5GHz Radio...
Originally posted by SFA View PostHi aspittles, could you please advise whether I can downgrade easily to 20170707 Build via the Update app with just uploading the 20170707 zip OTA, or I need to do some other complicated steps. Apology for my noobish understanding of the rooting process and TWRP.happy to help if I can...
I'm not aware of a way to downgrade as such, i.e. change the Firmware version and keep your config. (Other people please comment)
But what you can do is blow the current image and config away and install an earlier version as a clean install...
If you want to do this, have a look at #147 in this forum.
http://freaktab.com/forum/tv-player-...037#post664037
Thank you for the prompt response. Most probably this will wipe out my current settings and I prefer to stick with 20170801, since the box is connected via CAT 7 Ethernet cable to the network. Will wait for future update and hopefully they will bring back the original logo and boot sound. I have noticed also that the box was renamed in Geekbench to VS M8S PRO. Any idea why they are rebranding?Last edited by SFA; 21 August 2017, 09:43.
Originally posted by SFA View PostThank you for the prompt response. Most probably this will wipe out my current settings and I prefer to stick with 20170801, since the box is connected via CAT 7 Ethernet cable to the network. Will wait for future update and hopefully they will bring back the original logo and boot sound. I have noticed also that the box was renamed in Geekbench to VS M8S PRO. Any idea why they are rebranding?
I'm seriously looking at going over to the Stock or Nano Android roms that Guest created. They are clean and no extra apps on top, so as you can customise them as needed, just as Google intended
http://freaktab.com/forum/tv-player-...7-1#post657555
Guest
Originally posted by Magendanz View PostSo what's the general consensus here? Should I based my next update on 20170707 or 20170801?
How was the Eclipse??
I finally got the 20170801 rom loaded. I doesn't like TWRP. Seems I had TWRP on the micro SD card I was using but Once the SD card was formatted and just the 20170801.zip only on the card it loaded fine. I looks like it is rooted. As Aspittles said it has the MBOX spinning logo but it has the standard interface. Not sure what the DRM info app that's been added. I'll be playing more with this one and compare a few parameters and apps to see what's been modified. Sure would be nice if someone making these changes could provide a documented changelog. Just saying..
First, let me introduce myself - I'm a total newb to the scene, but do have a technical background. I've managed to root my new M8S Pro (2GB/16GB) and having fun playing with it. This is the 2nd box I've ever bought, but not fiddled much with the 1st (ended up giving it away).
Originally posted by aspittles View PostNo Idea's on the re-banding, sorry. Seems like a step backwards though to me though, as the 20170707 build fixed a bunch of stuff and the 20170801 build seems to break it all again, and brought back the buggered random apps.
I'm along the same thoughts as aspittles in wanting the next update based on 20170707 as it seems pretty stable and doesn't have those weird unnecessary apps installed. If 08 version proves to be a marked improvement, then Guest, you could always do another update later on
On a different matter, I was going through the APPS in the settings and saw 2 for YouTube. Thinking the smaller app was a system app and not the updated YouTube app, I uninstalled it, but now I can't add the YouTube app to the MeCool launcher screen - it also doesn't appear in the APPS screen. I can still access the app via the Apps list in settings though. Anyone know how to fix this?
There are currently 1721 users online. 1 members and 1720 guests.
