MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/16GB Dual WiFi Fast Lan BT4.1
Originally posted by neutester View Post
Hello guys, yesterday I received my M8S Pro (not L) and the first thing I have done is to remove original fw and install the one created by Magendanz. I knew that only the L version has the L1 widewine but installing DRM Info it tells me that this one has L1 too. It is possible or is only a DRM Info error? I tried to install Netflix but worked only Breaking Bad (at HD resolution) and other series play only audio or freeze the whole system needing a reboot. Anyone that has bought this unit in the last days has L1 in DRM Info? Thanks and sorry for my english.
For every one who want to change default Launcher, here a tutorial from 4pda .
First. Need a root
Install Root Explorer Explorer with root resolution.
I go to the system / app I delete the lancer VSLauncher2
Download Nova Launcher r from the market or it is possible with 4PDA, in the settings we allow lancher system settings, in the settings of Nova Launcher I make it the default by default, in build.prop I delete the line ro.platform.has.vslauncher2 = true
Reboot the box.
All at once you will have a Nova Launcher.
edit
I just tried it and YES it worksLast edited by paiktaras69; 14 October 2017, 13:26.
Hi guys! Just updated to 20171030 and I am very disappointed with this build. Let me share the missing items after the upgrade:- The official Google Play Store application is not anymore compatible with the device. It forced me to uninstall Google Play Store v8.4.18.V-all and an Android version 7.. came preinstalled. Of course the majority of the applications I use are not presented in this play Store.
- Notification bar is missing
- Navigation bar is not presented
- Many settings from Settings sections are missing.
Could somebody be so kind and advise me whether I can downgrade with OTA application to the previous version 20170919, or i risk a brick if I use this method.
Thanking you in advance for the help.
#232.1Guest commented04 November 2017, 08:34Editing a commentThese changes will probably also be present in 20170918.111557.V0619. You'll need to go back to earlier versions like 20170817.103347.V0321, which were based on the standard mobile Android platform and not Android TV.
If you want the non-ATV experience on the latest firmware release, though, you can always install the Nano or Stock variants of my Nexus custom ROM. http://freaktab.com/forum/tv-player-...ms-android-7-1
Thank you for the prompt replay, Magendanz. I will go with the previous OTA firmware MECOOL M8S PRO SD 20170817.zip. Do you believe that it is safe to downgrade with SD card and OTA application? Also this policy with the Android TV, can we expect it in every new firmware build?
Originally posted by paiktaras69 View PostFor every one who want to change default Launcher, here a tutorial from 4pda .
First. Need a root
Reboot the box.
edit
I would like to change my launcher and I can find most of the references in your post, so I am almost ready to give it a go :-)
I am not sure how to do these two steps:- " in the settings we allow launcher system settings, in the settings of Nova Launcher I make it the default by default".
Are you able to provide more detail on how I do this 'in the settings we allow launcher system settings' and this 'in the settings of Nova Launcher I make it the default by default'?
Originally posted by Jeffers View Post
The first step from all this process is to rooting the device
Are you able to answer my queries:-
I understood that and most of the other steps.
Sent from my 1+3T
First. Need a root
Reboot the box.
edit
I just tried it and YES it worksnow I can have any launcher I like on my Mecool box
Before applying your changes I copied the VSLauncher2 app and build.prop file, just in case
My Mecool was already rooted and I used ES File Explorer to delete the VSLauncher app.
Thanks for posting information, worked for me toonow I can have any launcher I like on my Mecool box
There are currently 4277 users online. 1 members and 4276 guests.
