The testing I did around the 5Ghz WiFi consisted of running a 2 hour+ movie on Netflix. On the 20170524 build and the 20170801 build the 5Ghz WiFi dropped after about 5 to 15 mins. On the 20170707 build the WiFi did not drop at all during the playback. I repeated the test 3 times on each of the 3 different builds. I also did the same test on the Nexus Stock and Nano ROMs (1 time only not 3 times) they too had the same problem with the 5Ghz Radio, but they are based on the 20170524 build, so this was expected.
What happens is the WiFi will just disconnect and I have to manually go back into the network config and tell it to reconnect. It doesn't seem to re-connect automatically.
During the 20170707 build testing the Netflix movie did stop once, however the WiFi didn't seem to have dropped and clicking on the Netflix play button resumed playing. So I just put this down to a Netflix gremlin and not a M8S Pro problem.
So from my observations the 20170801 seems to have been based on the 20170524 Rom, but they for some reason have changed the startup video and added a DRM App and Update script is looking for a "M8SPRO" device instead of a "q20x" device.
Interestingly my 1st M8S Pro (3Gb/16Gb Variant) came with 20170419 build and my 2nd M8S Pro (3Gb/32Gb Variant) came with the 20170707 build pre-loaded. Neither of these builds had these crappy MgmtSupport & BCenter Apps which crash randomly and seem to have no real purpose that I've been able to find so far. So they seem to have been introduced by the ROM's made available on this forum.
Guest Do you know where these ROM's with the MgmtSupport & BCenter Apps actually come from?
Sorry but I don't use the standard M8S Pro VSLauncher, I'm not a fan, I run TV Launcher on my 1st box and Nova Launcher on my Test box. If you have time you should check out Guest Nexus Stock Rom for the M8S Pro. http://freaktab.com/forum/tv-player-...7-1#post657555 It's very clean and stable ROM.
