MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/16GB Dual WiFi Fast Lan BT4.1
Couldn't find this thread after the forum change so made a new one in the MECOOL/VORKE thread but just in case:
A USB IMG has now been uploaded for the M8S PRO:
M8S_PRO-NMF26Q-20170524.163713.V0321.img
I am currently downloading
Was offline most of yesterday but here you go:
HTML Code:https://mega.nz/#!cSxTUTzB!o8g7nWbEBBSDi67GmPTWz9FJZS6oAZzHjbO1jZ3G-Lg
Eddiepropane hope you were able to download the file. My Chinese not good enough to get through the process. If you got it please pass it along. Second problem I'm having on this box is downloading a file. I don't know if it's the box or android 7.1 not letting the file write to the usb drive.
Thanks in advance.
I have purchased a MECOOL M8S Pro. Upgraded to latest Firmway (24/05/2017). All working well...
Only problem I have is that I don't seem to be able to override the M8S Pro startup App (Launcher). I've set the default launcher but the M8S Pro always seems to override it on startup.
Has anyone solved this?
Adrian
Guest
Originally posted by manubarra View Post
I noticed some slight improvement on my device but now have 2 small icons permanently in the top left of my screen on the status bar which I cant get rid of.
The two icons are BCenter with strange bbbbbb and cccccc written there and an icon named MgmtSupport.
Is it the same for anyone else with this firmware. Is there some way to get rid of them?
Can't say I noticed this when I updated my device this morning and when I rebooted it this evening, I notice these odd icons.
Â
Originally posted by Comeandgetme View Post
I've downloaded and installed the firmware.
Â*
I don't seem to be able to downgrade my firmware and go back to the 05/05.2017 edition that didn't have this problem....
24/05/2017 does seem to have fixed the problem with the button bar at the bottom of the screen not showing.
Still can't override the M8S Pro Launcher though!!! Really need to fix this....
Guest
Originally posted by aspittles View Post
Yes I too have seen this problem with the 2 notifications in the top left. The BCenter also randomly crashes and pops up a message in the middle of the screen saying "BCenter has stopped working, click OK to continue" or words to that effect....
My device on the 05/05 firmware, when I played live streams in websites (ustv for eg.), it resulted in my device locking up trying to play the video and I had to always force a shutdown. With this newer firmware 24/05 I do not have that problem anymore.
I noticed when I installed adguard today, it stopped/blocked only the Bcenter icon in the top left corner. Being suspicious this makes me wonder what kind of spying this firmware/device manufacturer has introduced in those 2 small icons.
Thanks for the reply, relieved that I am not the only one with the problem. I hope they will fix it but I don't have too high hopes on that. Every time they issue an update they seem to introduce some additional problems.
I do remember seeing BCenter on the 05/05/2017 firmware, but it just seemed to start and then disappear, but now it hangs around until it randomly crashes.
Interestingly I get ddddddd and cccccc instead of your "bbbbbb and cccccc" not sure there is any relevance on this though.
@tßeboß Any thought on this or how to override the M8S Pro Launcher?
Morning to all, I both one Mecool M8S pro 32GB ram and 32GB rom. when i set and connect to my TV and power on my tv box its start booting and when the Meccool name show on the screen its stop there and the remote is not responding. Ihave done reset and data factory reset and then started to work and and most problem when adding apps from store it always hanging and remote not work again, when i remove the power plug to reboot then the display stuck again at Mecool words. I have done flashing withe the update on version date 20170524. 1.3GB image file. but the problem still the same. please kindly advise me if there is still hope to repair the box. thanks
where i can find custom rom version erlier than may 05 relased?
Originally posted by paddygarcia View Post
I tried this with OTA offline, put the zip in a USB key, but when the box reboot I get: "error! ... failed to map files, installation aborted!"
Am I doing something wrong?
i flash with image file dated May242017 version but problem same. can i load this update as erlier version? https://yadi.sk/d/BsZXPQua3Jo4st
There are currently 4281 users online. 2 members and 4279 guests.
