iBerry BT-07 - Finless 1.4 Full Root ROM with latest Google Play Store
I need an stock ICS ROM that works on the iBerry. I cannot port ICS for you as this is a major change with the kernel.
Originally posted by rockyaryan08 View PostDear Bob and developer,
ANy new of install ICS on Bt-07 tablet with rooted rom?
can you work on it ?
I have one ICS rom that i install on BT-07 but after booting,, its not go forward. TOuch screen not working.. shorly i will provide link for that to workout........If touchscreen works, wecan do something...
thanks,
Give the link of ICS ROM
FInd ROM for RK2918 here .
This is the Rom that works and Install on Iberry BT07 tablet,, problem- after booting touchscreen not works, so we can notgo further forward.
check the link below:
download : Applied to Official Newsmy FW: 20120307K7T7M7N18zhengshiban4.0ruanjian.rar
Try to check this link , as you find some solution.
Any one find the Root rom of ICS for Iberry BT-07...
Originally posted by rockyaryan08 View PostThis is the Rom that works and Install on Iberry BT07 tablet,, problem- after booting touchscreen not works, so we can notgo further forward.
http://www.pandawillforum.com/showthread.php?12373-Jelly-Bean-(Android-4-1)-for-Cube-U30GT-H
Using the ROM kit, try reflashing only system.img. This way you wont loose your data, etc.
There are currently 2489 users online. 3 members and 2486 guests.
