iBerry BT-07 - Finless 1.4 Full Root ROM with latest Google Play Store
    Well explained Bob. I will keep that in mind.
      Thanks BOB/Finless and freaktab.com...
      Today i got sucess in getting my BT07 iberry Rooted with custom ROM Iwas try and searching on net but Biplab and BOB has made it reality .
      BoB has very well described about rooting and points to be kept in mind specially DOUBLE EDGE SWORD...thanks for explaining Beautifully in simple terms ...Hope to be get enlighten on rooting and getting help resoling the various problems faced in this android iberry tablet..
      we find it not possible to remove the USB drive every time it has to be shut down..otherwise it re-starts..any easy method to overcome this problem like unmount we do for sd card???
        Where is download file for IBERRY-BT-07 Rooted ROM.
        Where is download File.. I not able to find it on this forum. Kindly give me Link direct download the Rooted Rom to my comput
        OK by request here is my 1.4 ROM for the iBerry BT-07.
        WARNING! This is one of the few ROMs that will not work on my 10G2. I have no way to test if this is a brick ROM. If it is I have made many RK29 ROMs before so I know I can fix it. You are on your own with this. Please make sure you have the stock ROM to flash back to if this one is a brick. I am pretty confident it is not but you never know since I cannot test it.
        Also please read the readme inside if you have question. One thing I would like help on in the readme instructions is how to put the tablet in flash mode! I do not know how to do that for this tablet so you would be helping others if you could help me update the instructions
        ____________________________________________
        WARNING! Remove your SDCard when flashing this ROM!!! There is a risk it can be ERASED!!!
        This has been a lot of work by many other people. I HAVE to give total PROPS to FreakTab user Fenice57. His first ext4 setup was not quite right. We all worked together and Fenice solved the problem by highly modifying the recovery system.
        ext4 explanation:
        Understand the history. After a ROM flash the recovery system formats everything. Well without a change in that it simply reformatted anything back to ext3. The ext4.ko kernel modules handled mounting an ext3 partition even if the mount command said to mount as ext4!!! It even reported it mounted as ext4!!! Go figure that one So lot's of testing and benchmarking later..... We have a real ext4 file system!
        So there was no ext4 file system to benefit from in previous work. The improved ext4 kernel modules gave a little performance add but not much. However Fenice57 worked HARD on solving this and modified the recovery system to stop the format to ext3. Sowa and myself also added in testing and showing the issues. But Fenice is the MAN! He solved it.
        Fenice57... Can I just say THANK YOU! Everyone that uses my 1.4 ROM. Please also give a hand to Fenie57!
        OK so what’s in this ROM 1.4
        It's the same as 1.3
        1) Full root with /system set as RW
        2) SU and Superuser.apk installed and given root permissions
        3) File system properly redone and blocked for NAND.
        4) Market 3.4.4 installed
        Whats added in 1.4 is:
        1) WiFi scan interval is changed from 15 seconds to 300. This may help some guys with battery issues. Myself, I do not have this problem but due to many asking for it, I put it in. If you want to change it back:
        Use a file manager and copy out from /system the file build.prop file. Copy it on your SDCard. Then copy to PC or whatever. Edit the file and find this line:
        wifi.supplicant_scan_interval=300
        Just edit the 300 back to 15 and your back to stock.
        2) ext4 file system.. Well I explained the work that went into this above but just to add. I have done extensive benchmarking with many tools. This does not add a huge performance increase to the overall use of the tablet. EXCEPT, and this is actually kind of benefit, Sequential Write of files to memory. Large file writes are over double what they were on ext3. Random Read and Random Write are about the same. So where you should see an increase is downloads to Tablet memory, market download and install speed, some apps that write to memory a lot, etc etc etc. Overall however, the tablet seems much faster to me but remember, I am the cooker so I am biased
        Ok well that’s it. I was working on a dual boot setup but that will have to wait for 1.5
        Here is the download link for 1.4
        ROM -> iBerry BT-07 version 1.4a with Google Play, by Finless (166 megs)
        OK so thats it.... I hope you enjoy my new ROM. Please feel free
        Again, this ROM was a combined effort from a few people and I could not have done it without them!
        Oh and also....special thanks to Freaktab user Daman for an awesome boot screen and a LOW COST boot animation that will show people if the Tab is bricked or actually booting! When I say a low cost boot animation I tested it. With out it the boot time was only 4 seconds longer! But the beauty is unlike complex boot animations out there, this one gives the user feedback showing something is happening rather than wondering if it is a brick! GOOD JOB Daman and thank you!
        If you the user wants to remove it, since you are rooted , just go into /system/media and delete the file bootanimation.zip. But I think you may find you like it so I personally enjoy it and will keep it
        Enjoy!
          Thanks you, for ROoted Iberry BT-07 rom.
          Can you please send me the file for download. I not able to find in this forum to download the ROM file on My PC.
          Thanks,
          ROck.
            Rock....
            pl read the FULL THREAD only then react(ROCK)----http://www.freaktab.com/showthread.p...gle-Play-Store
              Thank u BOB & Finless
              hi bob&Finless,
              thank u so much for the custom rom. very good work keep it up i face one problem my tab getting soo hot.
                Advantages
                I haven't faced the heating issue in the custom ROM, at least it doesn't get warmer than it used to be. A few other advantages are...
                Boot screen
                Start up time
                Better touch
                Longer battery life... more than 4 hours while using my 3G data card
                Open GL 2.0, Stock ROM had v 1.1
                Better gaming experience & media player performence
                Supports flash 11
                wifi tethering
                you can use apps like TITANIUM BACKUP & get the whole backup of your existing ROM.
                The space for installing apps is increased to 1GB, stock ROM had 256 MB space for installing apps.
                etc.etc...
                  hi Biplap,
                  it's working great i feel that touch so smooth. previously i use Iberry Jan Update that time that time i getting normal worm. now little bit increase.
                  biplap tell me some best games for this tab. and which data card you using plz give me the details
                  Boot screen
                  Start up time
                  Better touch
                  Supports flash 11
                  wifi tethering
                  etc.etc...
                    generally I don't play games in the tab. The QUADRANT standard score is increased after installing the new ROM. The pre installed ANGRY BIRDS is working smoothly.
                    I use Huawei E173 datacard (Reliance 3G UNLOCKED) with a BSNL sim card
                      Thanks,
                      ROck.
                      I think you have checked the REMEMBER ME check box in the freaktab login page. I would suggest you to LOG OUT first & then LOG IN again & download the ROM by clicking the link...
                        Thanks a lot
                        ext4 explanation:
                        Enjoy!
                        thanks a lot for u r xcellent work...vl install today....
                        hope u vl do ICS soon...
                          jst installed
                          thanks a lot once again, jst installed without any glitches....
                          gonna install other apps...
                            I agree. I have also faced the USB UNMOUNTED UNEXPECTEDLY error & system RESTART. ummm I would suggest you to kill or exit all the applications that are using the USB device content, like video player, document readers etc. Kill all the apps using GO TASK KILLER app & then remove the usb device, this is what I exactly do before removing the USB device.
                              Wait... you guys are telling me you do not have a way to shut down USB devices?
                              On other Gingerbread OS, you pull down the top status bar and you will see USB "stuff". Click on the USB item in notifications and you should get a screen allowing you to turn it off. I have to believe there is a way to do that in ICS or Honeycomb?
                                Unmounting pendrive
                                There is a TURN OFF USB option in the notification bar ONLY WHEN the tab is connected to pc in MASS STORAGE MODE. But the ls no option of SAFETY REMOVE USB FLASH DRIVE when we connect a PEN DRIVE to the tab. This happened to the stock ROM too...
