Its better and good to use the Original firmware (2 firmwares provider by iberry officially) for smooth and better performance. But if you want to play with (if you are a tech addict or if you want to do some Research ) then go for it.
iBerry BT-07 - Finless 1.4 Full Root ROM with latest Google Play Store
iBerry BT10
Originally posted by advnar View PostIts better and good to use the Original firmware (2 firmwares provider by iberry officially) for smooth and better performance. But if you want to play with (if you are a tech addict or if you want to do some Research ) then go for it.
Thanks in advance
cheers
ics on bt07
hi everyone just a suggestion, iberry has released ics for bt07i, and there is a update link for existing user with 2.3 for up-gradation to ics. now can we use the same rom and apply it to bt07.
hardware wise only major difference is the touch screen i guess the rest is the same.
so this is something to work on.
Originally posted by nilang View Posthi everyone just a suggestion, iberry has released ics for bt07i, and there is a update link for existing user with 2.3 for up-gradation to ics. now can we use the same rom and apply it to bt07.
My ROM uses RKAndroid Tool. The stock ROM uses RKBatch tool to flash update.img.
So to flash back to stock you must use the RKBatch tool that comes in the stock ROM kit and in that tool load the update.img file. FLash the tablet with RKbatch tool choosing the retore button! Do not use the upgrade button.
ext sd card to internal sd??
Recently on my NXG XTAB A10(LY-F1) ICS 4.0.3, I was surprised to get a custom ROM where External SD card was changed to internal memory and vice versa.it gave great freedom to have 16GB or 32GB SD card as internal memory. Bob can it be done on BT07 as it has limited internal memory2GB only..thanks for all the help and guidance for we new comer(late comer) to android arena...a sharma
help plz!!!
Originally posted by biplab View PostThis is what I get... I hope it will help you figure out how to put the tab in FLASH mode... I quote... ""To reinstall the firmware follow the below given steps: 1. Switch-off the tablet and connect it to the charger. 2. Connect the USB cable to tablet (But don't connect it to PC) 3. Press and hold the ESC button of the tablet and simultaneously connect the cable to PC."
Originally posted by drajax View Postplz help!! im a noob who bought the tab only two days back..twas loaded with ICS. but as i need to root it i thot id dld the custom fw and flash it!! MY QUESTION IS WRE TO FIND THE ESC BUTTON?????????? is the power button the one?? i got only volume up/down and power button!! and tried pressing it while connecting the USB cable to the PC, but still the flash app(rkbatch tool & rk29update does not detect the tab!! so help is very much appreciated. thanz in advance folks
Regards
Biplab
Originally posted by biplab View PostI think you are talking about BT 07i, but mine is BT 07. I really dont know where the ESC button is in BT07i as I haven't examined the device... As far as I know BT07i is a PRE ROOTED device. you don't need to ROOT it again... Download & install ROOT CHECK BASIC app to confirm your device is rooted or not. Regards Biplabi didnt know twas PRE ROOTED :S wot an idiot :s
Originally posted by drajax View PostOMG yeah mine is the BT07i tab :O ive messed it up now :s and now the internal C drive is not respondin after i installed Busybox and superuser app :s and i got no idea how to reflash the damn thing :si didnt know twas PRE ROOTED :S wot an idiot :s
Tell me a few things first.
1. Have you tried to flash your BT07i tab with the custom BT07 ROM...?
2. What do you mean by NOT RESPONDING..? Does it hang when you browse the /SYSTEM folder or something...?
3. Have you installed the prescribed ROOT CHECKING application in your tab...?
Swyped from drajax's Galaxy SL!!! *
Hit thanz if I helped!:P
" Tomorrow .... its a brand new Today "
Originally posted by drajax View PostYeah I tried to flash the custom ROM, but as u can see I could not get the Esc button! Hence I dlded the stock ICS ROM & installed it again from the sd card!
Cheers
\m/
There are currently 2435 users online. 1 members and 2434 guests.
