[ROM] NEW Beelink GT1 / for both 6255 & 9377 Chipset Alvatech ROM
Originally posted by ALVATECHOkay everybody. Sorry about the ok button not working. Here is a link to the updated kl file:
https://drive.google.com/open?id=0B_...TdoWGpkbjhzbnc
Location of file that needs to be overwritten is in Root: /system/usr/keylayout
Remember you'll need file manager like X-plore. Then when you're in X-plore go to top right corner and click configuration. Then go down to the Root access section and select Superuser + mount writable. Then copy new kl file over and overwrite old one. Then restart the box and you should be good to go.
I will update the ROM on Monday when I have more time. Have plans this weekend. But this should get you'll by for now.
I think this has to do with country code (maybe timezone) on your box and or your router. Usually in USA channels that are used are 1 to 11, in Europe 1 to 13. I'm from USA and I can't change my router to EU country code and I don't have an option to do so to test it. But I'm thinking this is the issue you're having. I haven't changed anything with wifi all of it is from original ROM. I think there's an app that can change country code. You'll need to google for it.
Originally posted by KAA View PostRouter channel base of country
my self in asia have channel 13
Alvatech, does this rom have the minix kernel or the original? I suppose the original. I ask it because Minix possibly already solved the cec problem.
btw, can be replaced the kernel from minix or there is something why it's not possible or not really compatible??Last edited by pszab; 12 July 2017, 13:15.
Originally posted by pszab View PostChanged the country code to eu but still only 11 channels are available. I don't know the official rom has the same problem or belongs to this.
New problem: twrp has a lot off error message, and If I save a backup I cannot restore it. Which twrp is in it?
I'm using the old 113 rom (has remote ok button problem) but I've checked the new one and I don't know why but 5MB smaller :-s. The kl file isn't so smaller.. What is the diff?Last edited by pszab; 13 July 2017, 06:07.
There are currently 1914 users online. 0 members and 1914 guests.
