[ROM] NEW Beelink GT1 / for both 6255 & 9377 Chipset Alvatech ROM
Originally posted by ALVATECH View Post
I would say try a different player such as SPMC from the play store or FTMC from here on Freaktab. These players seem to have better compatibility with amlogic devices. Since you were having these problems with supercelerons ROM as well with these files, I would say it is the files that are being problematic but don't quote me on that. To be honest if trying these players doesn't fix your issue then I would say your next step would be to post on forums where these different players are being developed. These forums could shed light on these types of problems and would probably give you better guidance as to what setting to use or to test. I do plan on releasing a newer version of my ROM with other fixes and maybe this would help your issue as well. Still your best bet is to ask on the according forums.
Originally posted by [email protected] View Post
SPMC solved the problem! The MP4 file plays super smooth. Thank you for the suggestion!!!
Originally posted by csavoia View PostHow do I check what firmware I have. I am using a g1 ultimate serial number starts with G912
Sent from my iPad using Tapatalk
Is there any firmware that fixes the dark video issue for the gt1 ultimate G912 version. I love the box but hate that I can't see any of the videos I try to watch. And I don't know what firmware fixes this. I am a newb for an android box but I think with good instruction I can upgrade the firmware as long as I know it will fix this incredibly annoying issue
Originally posted by csavoia View PostI don't have anything happen when I click on catharsys. Is there a link to find out the name of this app or apk?
I am just tired of how bloody dark the picture is. How can there not be a fix with the amount of boxes they sell.
Sent from my iPhone using Tapatalk Pro
Ok I did that and she no longer has anything asshe says superceleron had something but can't locate him on here anywhere. If anyone can hell please help.
The box is GT1 Ultimate with G912 as starting numbers in serial number.
I am ready to throw this stupid thing in the trash. Please anyone please help.
Some things I want to mention after quickly trying to set this ROM to my needs.
First am trying to have the old Off function in order to work with Wetek launcher Off icon but when I am uninstalling Power Menu App then I cant use the default Off function (say SystemUi error).
Second there is no "all" key in order to clean all the apps onto the task manager and I have to clean one by one all the open apps.
Third but not so important, a black bar is showing when Play Store is open at the bottom (it is like I have the bottom bar open but without icons).
I loved that the top bar can be disabled, I loved the responsiveness of this ROM, brightness fix I think that works well by default!!
I ll come up when I play with this ROM more. Thank you Alvatech.Last edited by johnickz; 20 May 2017, 18:41.
Hi thanks for the rom just a small problem. I installed this on my entertainment box t8-v5 using the sd card and had no problems installing. After first boot I plug my minix air mouse in and can't get it to work. The standard remote that came with the box the only button that works is the power button so I can power on and off but nothing else. The USB have power cause when I tried to power a gadget the lights came on.
Any ideas lads cos I just don't like the launcher that come with the box it has no Notification drag down option
There are currently 4329 users online. 0 members and 4329 guests.
