thanks
[ROM] NEW Beelink GT1 / for both 6255 & 9377 Chipset Alvatech ROM
Just for the record - I installed the 6255 img on my Intbox I7 and it appears to be working fine. Although I've also seen other people say they've used GT1 / 9377 firmware on their Intbox I7 so I'm not really sure what the deal is. But wifi is working. I couldn't get either of the 2 USB ports to work so I used the Bootcard maker. http://freaktab.com/forum/tv-player-...maker-v2-0-0-2 The button for Recovery mode is in the A/V port.Last edited by hyc; 11 May 2017, 10:56.
Originally posted by hyc View PostJust for the record - I installed the 6255 img on my Intbox I7 and it appears to be working fine. Although I've also seen other people say they've used GT1 / 9377 firmware on their Intbox I7 so I'm not really sure what the deal is. But wifi is working. I couldn't get either of the 2 USB ports to work so I used the Bootcard maker. http://freaktab.com/forum/tv-player-...maker-v2-0-0-2
Originally posted by [email protected] View PostAlvatech, thanks a lot for this ROM.
I keep having issues with mp4 playback. I've tried different videos and players but it keeps crashing. Do you have any suggestion on how to fix this problem?MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
Originally posted by ALVATECH View Post
I've noticed you posted this same error you're talking about on superceleron's ROM as well here. So if it's not working on his or mine I'm thinking their might be something wrong with the format of the mp4 file you're using and or something to do with the player your trying to play it through. Kodi can play a lot of different files. So have you tried with kodi? and or other players? Also like KAA had mentioned what are you trying to play from? That also can make a difference. Try this, download a different sample mp4 file from internet and try playing it from different sources such as internal memory, external memory, sdcard and hd and see if it plays properly. If it does then it's more than likely your file('s). Remember we need detail in order to help. Also if you can share a clipping to test that might help too.
Thank you very much for replying. However, my cooleme mb2 box got bricked while I was flashing another firmware. I am hoping to unbrick it!
After many tries, I managed to unbrick my box. I have tried Kodi and other players to play these problematic mp4 files.
I am playing videos from an external HD. Some videos play normally but some struggle and get stuttered or the video player just crashes.
This particular one is x264, mp4. What other type of info do you need? Is there any change I could apply to Kodi?
Thanks a lot!
Hi! ALVATECH
Thanks a lot!
Originally posted by johnickz View PostHello Sir I want to try your ROM but I am waiting about an update you told about. Will be released soon enough in order to wait?? Thank you.
There are currently 2701 users online. 0 members and 2701 guests.
