[ROM] NEW Beelink GT1 / for both 6255 & 9377 Chipset Alvatech ROM
Originally posted by [email protected] View Post
Originally posted by ALVATECHOkay, I made a new updated ROM based on the latest 113M0 from Beelink. Please go to the first post to see changes made to the ROM. Hope you enjoy it.
Problems:
1, twrp is nowhere, original recovery comes up. I've tried to flash it with dd as i did it previously on original rom but it wasn't successful (dd says ok, but recovery remains original). Tried it twice but not working. I don't know why
2, no wifi no bt. My device is a912. I tried to update AT_AP6255_UPDATE_V2B.zip with update &backup method but update finishing with error (in recovery)
3, bug: no keyboard at adding google accountLast edited by pszab; 07 July 2017, 18:08.
Originally posted by miltosdelis View Postthanks for the fast response i donwload the full rom and the update zip and tomorow maybe i install it to my a912 beelink gt1 tvbox
Not sure why your recovery isn't working. Try to flash again with USB Burning Tool then maybe try selecting the options under Configuration to: Erase Flash and also try force erase all. See if this will fix the recovery option then you should be able to use the update zip for Wifi & BT to work. Let me know how this works for you. Also the keyboard bug you talk about is on all of the Custom ROM's for the GT1. This is a bug with amlogic and googlewebview this is out of my control.
i forgot to mention the bug of non-working ok button as well.
This remote: https://des.gearbest.com/uploads/pdm...2636_98929.jpg
Okay awesome I'm glad it worked for you. I must of replaced one of the kl files that mapped that remote. I'll have a look and see what happened. Don't worry I'll fix it and also give link to kl file for those who don't want to reflash and to those who still use original remote. I don't use that remote so that's why I didn't notice.
Don't you use the original remote or more original types exist?
For me that was in the untouched foild box but now in the net i can see another one. This https://androidtvbox.eu/wp-content/u...g-1024x576.jpg
Not too good if more types are attached to the same box
Which remote are you using?
Originally posted by pszab View Post
2nd flash was successful.
Both. I don't use the original remote and also I use a different remote. I use the Rii mini i8+ remote. This remote works really nice. Also yes I have seen other remotes being sent out with the GT1 boxes as well. Once I figure out what happened I'll tell you know what needs to be done. Thank you for your patience.
I've tried official 109, 110, 111, 113, magendaz tvstock and nano roms. Bluetooth file share between my phone and gt1 was wrong on all of them.
BUT ON THIS ROM THE BT FILE SHARING IS WORKING!!! FANTASTIC WORK.
Do you know it why, Alvatech? Is any intentional modification on it?
Btw, the cec is the same on all roms. If i press channel +/- the tv disconnecting from this source and switch to tv. Lots of buttons aren't working. I've tried libreelec and all of the buttons working well. Do you know it's possible to migrate the cec from libreelec to this rom?
According to developer Kszaq LibreELEC includes libCEC implementation and need to have full Android source code as it's not only kernel part but also userspace. Is it all available for us?Last edited by pszab; 08 July 2017, 13:02.
There are currently 2150 users online. 0 members and 2150 guests.
