news about h96max? Regards
H96 MAX RK3399 Tv Box 4/32GB
Box with case:https://youtu.be/iqerzCSm-p0 - Go to 26 minutes Box no Case: https://youtu.be/HrubwtaybbQ - Go to 5:30 minutes he difference with the case does not even reach 20ºc! There was a brilliant idea to put rubber in to reduce the heat, and the case still has no cooler! If it had a cooler it would not even reach 75ºc with 4k60fps 400mb x265
Yes I have this box you mention thanks for the information.
$20 or so cheaper for the H96 Max at Gearbest may be more appealing to others
Again thanks for the Info
Lets today have a look at the H96 Max
Thanks to Gearbest and DHL super fast as always, Hoping for something Interesting but looks like the same H96 sort of build
Boring remote and the quality of the build looks rushed, USB C port out of line some creative bending and packing looks better.
Lets start with the look around.
Originally posted by trebor View PostFirmware is may 26 still Playstore problems
What Issues are you having with Play store ???
How can I find a List of Issues So I know If I fix them ...
Also a List of Test Videos to see If I fix them ?
thanks
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Originally posted by trebor View PostMany apps incompatible,
Runs hot (not good heat sink or box) but more like kernel I feel
Not looked at video's as yet others can help
Seem to be a lot of TALK about quirks...
Just the usual new out of the box type of issues.
Where is the Firmware Install Button on the R99 r-TV box there is a little hole next to power button plug ... You put Tooth pick in hole to press button to
Put player in install firmware update mode
Help please
There are currently 3970 users online. 0 members and 3970 guests.
