H96 MAX RK3399 Tv Box 4/32GB
i used ROCKCHIP RK3399 MACTCHBOX H96 MAX .FIRMWARE 7.1.2. thanks you all, i decided to give up and request to my seller will exchange this unit, i feel its a faulty deviece since day one, i had this only for last 15days , taken back to store tommorw and exchange it , thanks you scootter 2014 and gefattern , i will come back tommrw to update you. thanks
No i didnot try new room.because its works fine at the moment IF I SWITCH IT OFF AND THAN ON..its work..basically its works like that.say.first i switch on and play any show and than switch off and switch on and same show comes and its work.so if scroll to other progm its sound goes off than i switch off n on and its work
Hi atiq33 ,
this sounds like a Power Problem , what Output does your Box use 5V/2000mah ??? , try one with 5V/2500mah or maybe 3000mah , but still 5V ,
of course must the Voltage always be the same . Please report what your Box is using , maybe it gets not enough Power to do the Job , because
the cheap Poweradapters dont bring the exact needed Power . Try and report good luck
gefattern
There are currently 5008 users online. 0 members and 5008 guests.
