Dozens of attempts either way and still no resolution. I often get a loader error. Please help me. I’m so close to ordering a Nvidia Shiekd Pro...though a crazy $460CAD
H96 MAX RK3399 Tv Box 4/32GB
Originally posted by HomesickSurfer View PostHi. Can’t start my new H96 Max R3399 4GB/64GB...no lights nor able to flash rom without stopping at a failed loader using either of several tools. Could it be a locked loader?...the unit was rooted when purchased. Can ADB get me into a reboot/restore?...
I have seen that poor quality USB cables, using Front USB ports or laptops can give grief with failure to burn..
just thoughts...
Worse case do a warranty advise it failed during and update.
Are you getting enough power to the device to burn
just thoughts...
Worse case do a warranty advise it failed during and update.Btw, this all began when I attempted to change the default screen layout to something else I can’t recall the name. It crashed then I couldn’t get it back up
The seller is a seller
Lodge a ticket on their website first, wait for a bit as this is silly season, they are busy so can take some time.
Advise of the situation problem you encounted they may ask you to jump through a couple of loops try this try that take a photo etc...Part of the deal
and go from there, it does work just takes time.
https://www.gearbest.com/about/warranty-and-return.html
Thank you very much. My wife is so mad that I bought this box and it’s not working yet her mother has a $30 one and watches everyday. Do you know why it loses power at about 20 seconds when attached to laptop and attempting to flash?
Originally posted by LeKodeur View Post
Had a similar issue with the Rockchip Tool ROM burning Windows software. The H96 would disconnect from the PC during the ROM transfrer initialisation phase within about 10-20 seconds of connecting. Turns out that the USB driver does not sustain connectivity long enough after first connecting due to lack of the proper handshaking signal/command from the H96 box to keep the USB connection alive, so the USB drops out after 4 retries and your ROM transfer never gets a chance to initialise properly. My work around was to disconnect the USB cable within about 8-10 seconds of pressing the 'Restore' button on the ROM burning tool and reconnect after a couple of seconds. Took me a few tries to get the timing right (depends on what ROM burning SW and drivers you use), but I eventually got the image transfer to kick-in and ... voila, it loaded in and the transfer was completed and checked successfully.
Oh wow!..so there is hope!. Can you please tell me what software you used and what version if you can please. I’ve noticed the same...I must try. Please let me know ASAP. Thank you
There are currently 3929 users online. 0 members and 3929 guests.
