and please install oktober firmware, and check if the box is de-bricked.
H96 MAX RK3399 Tv Box 4/32GB
As Found not tested, use at own risk
H96 MAX RK3399 ANDROID 7.1 4GB/32GB TV BOX FIRMWARE UPDATE 20180102
PC Flash Firmware
Filename: rk3399_7.1_new_H96max_P_A_E_1.5M648M_ear_180102.im g
Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
Source blog.geekbuyingLast edited by trebor; 01 February 2018, 10:24.
Guest
Originally posted by cnymalenurse View PostYes but you still cant change the launcher to anything decent like Nova Launcher and forget about changing wallpaper with it.
Originally posted by @curious1 View Post
After trying many, I discovered Buzz Launcher works with H96 Max. Not Nova but pretty good. Also found a gallery mod on Apitode that allows wallpaper placement in Buzz.
Guest
HEADS UP The 180102 img hangs up on the H96 max screen, doesn't even boot up. Back to the drawing board...
BanzaiBABY it is on Apitode, called either Motorola or Samsung gallery, modded to work on other devices. I'll look again.
Guest
Finally got my box back up with the October firmware. To get the working Gallery app go to Apitode type in gallery. Third one down, 423k downloads, 4.6mb, uploaded by leecs.
Originally posted by @curious1 View PostHEADS UP The 180102 img hangs up on the H96 max screen, doesn't even boot up. Back to the drawing board...
There are currently 2591 users online. 0 members and 2591 guests.
