H96 MAX RK3399 Tv Box 4/32GB
Originally posted by RicardoBR View PostMine is the same, I already found the pins, but I do not know what to do now, how do I do it? Help me please, I'm desperate.
nearly the same Way as flashing , short Pins , connect USB , connect Power , wait for MaskRomMode & flash your Box .
good luck / gefattern
Hi ,
I can not do the translation of what you said, but I know how to do the maskrom, it's easy, but the pins on my board are different from the others, they are two pins, I do not know how to do both at the same time
first do you want to fool me , if you can translate to ENGLISH it is no Problem to translate back to your language , otherwise get a Friend ,
with Brain , to help you , use a thin bendable cupper wire or similar . If you know how you bring your Box to MRM , just do it and flash .
If your Box is already in MASKROMMODE you only have to press on the FLASHTOOL / UPGRADE / RESTORE , really cant understand why
you are not able to do a simple Thing like that . Search for YT Videos that you can see .
Hint : i am only a User shows you the right direction , the rest you have to do .
Hi ,
I think you did not understand what I meant, the only thing I need to know is the position of the wire, how should I position and touch it
Hi ,
I did everything right, I entered the maskrom mode, but even then the pc does not recognize the box
that is not correct , if your Box is connected in MRM to PC it is already recogniced by PC ,
you only have to press Upgrade/Restore in Flashtool , simple as usual .
greetings / gefattern
Hi ,
Anyway, I'm sorry for the inconvenience, thank you.
Originally posted by RicardoBR View PostI think I did not explain very well, the box connects to the pc but it keeps warning that it is malfunctioning without stopping, and I listen to the sound of windows when it connects, and the sound does not stop.
this sounds like a Problem with the Drivers are they installed and what Drivers did you use ??? ,
and which Windows Version do you use ??? please report . (as possible use Win7/64bit)
Hi ,
I tried on windows 10 64bits and windows 7 32bits,
none worked, I installed Driverassistant v4.5
do you use the right USB Cable and the right USB Port to connect the Box ???
Hi , what does the DeviceManager of Windows say if you connect the Box , what pops up ???
Originally posted by RicardoBR View Postmessage from windows: usb device not recognized, the last usb device connected to this computer has malfunctioned and windows does not recognize it. this message appears non-stop. I connect to the usb 3.0 port of the box and the 2.0 port of the pc, but I've tried all
please look for a WindowsTool called USBDeview , install it as Admin and uninstall all connected Devices from List ,
reboot and try again , if something unclear with this Tool use "big G" to find Tutorial , simple to use .
Hi ,
is purple, connects and disconnects without stopping, and the warning does not stop.
There are currently 1496 users online. 1 members and 1495 guests.
