you wrote........ Another thing that does bother me a little is that sometimes when i watch a movie ( and it really doesnt matter if i play the movie via KODI or FTMC or plain old MX Player ) the picture goes away for like two seconds like the Hdmi had been plugged off and on for those two seconds but it might just be because of the HDMI cable for all i know. . .....
I'v the same/similar issue with my X99;when I play movies/clips from my ext.HDD(Toshiba Convio1Tb)>>via KODI/MXPlayer or such another Player too...
but mine issue not with HDMI Cable,when I go to playing movies or clips internal settings(such as Audio or Video settings Section) than when I started
to adjust some of values than movie/clip stopped and on the screen warning>>>"USB device mounted" WTF
and than returned to Main Menu!!(Device Launcher window)!!!
RK3399 seems handshake issue with a lot of programs/applications etc., might be Android 7xxx issue(I never tried 6xxx) or something unknown happens
For RK3399 at present "The reality" is only one point;"Picture Quality" thats all or you can add to this "Fast Device"! so let say Pic.Quality+Fast Device thats all
FYI;"Kodi Player" way better than MXPlayer!! so you no need to installed MXPlayer!!
And also internal Player even better than MXPlayer!
Bye++
