anyone able to get dts passthrough working with these?
kodi crashes black screen and i noticed the sound setting brings up dolby as being unsupported, tho reviews i had seen listed it as dolby ready
*edit * 4 hrs later and ...
now its dead just the red spdif light
the display started turning on / off then did a reboot and that was that
also, anyone got another AndroidTool 2.42+ link the AndroidTool_Release_v2.52.zip seems to have a corrupted file?
*edit*
or is another compressed format inside the zip? without an extension listed ..
# file AndroidTool_Release_v2.52
AndroidTool_Release_v2.52: POSIX tar archive
sometimes I just love linux
renamed the extracted file inside the zip to AndroidTool_Release_v2.52.tar and extracted
well, progress now used pair tweezers to short pins A+B while plugging in USB ( half plugged in to make it easier to slip in later ) followed by power then removing tweezers short using AndroidTool_Release_v2.52 to reflash and now seem to have a working OS again :P
I have a feeling that big bit of metal they have floating around (part of wifi ?) is causing a short making these brick ...
I used to run vantec iceberq 4 pro on my mainboards might see if they will fit these chips , also looks like peeling back the sticker could gain air flow acess to the chipset as well more so amazed they have a fan header but could not be bothered installing a $3 fan for us
Android 7.1 seems to have working dts passthrough
rk3399_7.1_new_H96max_APK显示_648M_ear_180713.img latest tools manual etc
edit*
the headers are 3.3v so going to use 5v USB fan adaptor
put some heat-shrink tubing over wifi metal part so it does not short stuff out again, moved screw that was drilled through pcb into its correct hole
hot snoted in an old Asus cross flow fan
