H96 MAX RK3399 Tv Box 4/32GB
Well...Guess what...
My box has fixed itself...
I uninstalled the Playstore updates in order to restore the old version so I could do updates today...
After updating apps my Playstore updated itself again...
Much to my surprise the version it updated to is WORKING!!!
I can now go into the Google Playstore as normal without any crashing....
My Playstore version is now 15.8.23-all
My Playstore services is now 18.3.81
Happy days... Give it a try uninstalling updates for the Playstore then let the Playstore update itself...Hopefully it will work for you as well...
Do i have to do anything to Playstore services to get it to update or should I just leave it alone?
Just a thought...
If it works, DON'T "FIX" IT.
... plus, I say, manually update your apps as You need.
"new and improved" is not always a good thing for Working Fine apps on these rk3399 devices.
ie: MX Plyer suks the bone. PlaySuk can create a lot of headaches... automatically.
it's the way they roll.Kris....don't forget my boxes! Okay?
currently trying to decide if I should cut my losses and sell my rk3399 with its fan mod or make it stock in which case its very slow, tho I would need to re-flash it for the remote to work again , not that I recall the remote ever working ..
gone back to running a 20m HDMI cable running to my main PC, I'll have to reset up multi-seating so the TV has its own dedicated keyboard/mouse without interfering with my desktop session tho
Originally posted by kurt6916 View PostThanks for the info. My Playstore works to. My Playstore version is now 15.8.23-all but my Playstore services is 17.7.85.
Originally posted by RiCkLaR_atvX View Post
There is an app on Google Play Store called "Play Services Info" that can force the stock Google Play Store to look for the correct update for Play Services and then you can update it directly from the Play Store. This is the best way to update Services apk because there are different versions of the Services apk for the different Architectures(32bit,64bit,x86) and for different Android versions(Jellybean to Pie) and for different Screen DPI systems. If you want to see these differences use Apkmirror.com to get to Play Services downloads, there is a small guide table showing the differences between the various versions of Services to help you pick the right one to manually install. But like I said the "Play Services Info" app is the easiest way to update it correctly.
Hi ,
i always debload my Rom , so no Calculator , but i am sure , it has no "odex" files , i heard the same about "odex" ,
helps starting apks faster , but i am not a Pro , the best would be , to test the PlayStore Problem with a fresh install ,
greetings / gefattern
Hope you can help.
Unpacked the product, H96 max android tv box, yesterday.
As soon as it is turned on, message displayed “bluetooth stopped working”. Multiple message windows needs to be closed down.
Attempting to turn wifi on, it turns itself off after a few seconds. Only wires connected are the power supply and HDMI cable to TV.
What other solutions are there to turn on the wifi without saying the product is faulty?
the Stockrom is shitty , try the Customrom of Superceleron for this Box , this shall help ,
but first we must know what Wifichip is build on PCB ???
There are currently 1819 users online. 0 members and 1819 guests.
