H96 MAX RK3399 Tv Box 4/32GB
guys here is latest firmware for H96Max (180713)
Originally posted by BlodVark View PostWhen flashing new firmware what i need to choose Upgrade or Restore in Factory Tool ?
backup and restore you APPS as well as your KODI installation when flashing new firmware. (Or reinstall everything).
Guest
Originally posted by JoseM View Post
Has anybody used the C-port on this box successfully? I purchased a type-C to USB adapter so I could plug something into the C-Port. I have never used any C-port devices before and the adapter I received is very loose in the H96Max C port and wants to fall out. Nothing I tried works. I don't know if it's the adapter that is the problem or if it's the H96Max C port that is the problem (Or whether there is a specific type of adapter that may work?) I purchased an OTG Data adapter Type-C to USB but it doesn't work so I'm not sure if there's something else I don't know about this type C port that is on the H96Max?
Originally posted by motox22a View PostHas anybody used the C-port on this box successfully? I purchased a type-C to USB adapter so I could plug something into the C-Port. I have never used any C-port devices before and the adapter I received is very loose in the H96Max C port and wants to fall out. Nothing I tried works. I don't know if it's the adapter that is the problem or if it's the H96Max C port that is the problem (Or whether there is a specific type of adapter that may work?) I purchased an OTG Data adapter Type-C to USB but it doesn't work so I'm not sure if there's something else I don't know about this type C port that is on the H96Max?
Type-C port like child play and seems never enough tug! I do not like it
My Box is X99(RK3399) I use sometimes this port and your describe is right this type port very loose/fall etc.,
No any spesific type of Adapter!
Note;do you have any pic. of your OTG Adapter?? just wonder!
gefattern
so i flashed 180713 firmware after a few mins of using the box freezed plugged out the power adapter and then it always stuck on h96 max logo so i tried to flash superceleron custom rom clicked run then download idb failand now it's bricked no power led only spdif red led i used driver assisant and factorytool provided by geekbuying
1. in androidtools maskmode should i click eraseflash first then upgrade or just upgrade ?
2. power adapter must be plugged in when doing this after box is recognized in maskmode ?Last edited by JoseM; 12 August 2018, 18:23.
The one I purchased is on Eb@y.... Does not work. Wants to fall out of the C port on the H96Max. Port on the H96Max is larger.
Originally posted by bergamesk View Post
same me!
Yeah...First I'm going to do is get my money back for this junk ($1.95)...I was hoping someone else here has tried using an adapter on the C port and found one that works and can post it.
Right now I haven't seen anybody post anything about whether the C port on the H96Max really even works. There's no place for me to obtain different adapters where I live so I have to order online for anything I would want to try...I don't want to waste any more money until I know for sure the C port on the H96Max really works and that there is a known good adapter for it.
Probably your Type-C port work! even all your USB ports work well,dont worry for that
Keep in mind;My Box(X99) Type-C works well but when I was bought my first Adapter(same yours type) does not work well!
-in the begining(just for couple of days)worked than out of order! so I drop it out! than I'v been bought another Adapter
and until now it works!(about 3months)
Importatnt Not;I forgot to write it,in May,one of my friend sent it his H96 Box to me in order to Testing and Type-C port well
no problem with my second bought Adapter as well!
check my post P.9/msg Nr.130 "X99 Thread">>> http://freaktab.com/filedata/fetch?id=732399
Adapter Brand "TRUST"
OK... That's good info... I already got my money back for the adapter so I'll be on the hunt again and will look for that "Trust" one...Thanks.
Edit: I found that "Trust" one on [email protected] the seller is in Poland and wants $9.34 plus $26.29 Shipping...
he is drunk
Where you live?
chech again e@bay site
that I'V found
"Double-Side Type C to USB 3.0 Type A Male to Female OTG Data Charger Cable Cord"
And which type Adapter you want? Type-C to USB3.0 MALE or FEMALE??
seems that Male type Adapters more expensive!
I'll wil buy a new one with Male end,I'v Female type but for use this type Adapter you will need
connection cable! (MALE-MALE type USB3.0,but also MALE-MALE type USB2.0 works!)
So for easy connection the best type is Type-C to USB3.0 MALE
There are currently 1594 users online. 0 members and 1594 guests.
