H96 MAX RK3399 Tv Box 4/32GB
Originally posted by RicardoBR View PostWhenever I flash the rom, this image appears and takes a lot, I already tested 3 roms, yesterday all 3 worked, but now this screen is taking a lot
help me
how long did you wait ??? , so , you already flashed the Rom , it booted & worked , but after
second time of flashing this came up , do you really used the same Rom ??? I think you only
have to wait longer ,
greetings / gefattern
Hi ,
It's night time here, I've been waiting since morning.
i really never have seen this , for me it looks like the Box is "erasing" the caches , but this normal not
takes so long , wait till morning , maybe 24h , if nothing try to connect and flash again , did you the
"eraseFlash" before you flashed this Rom ??? Somewhere here i read about a User who had to wait
a hole Day ,
Hi ,
a hole Day ,
Is there another way to clear the cache?
Originally posted by RicardoBR View PostI use the factory tool for flash, but I do not find the "erase flash" option, and I also can not access recovery mode to clear the cache
Why use factory tools that don't support Nougat firmware correctly?
Use AndroidTool v2.43 to flash.
Originally posted by negher View Postmo123 - Suggestion for my problem? No audio in "Media Center" and "Video". No possibility switch off Off. All OK WiFi.
Firmware 2018.1.24
Try to turn off with the ir remote power off button, if it also doesn't work then this device is terribly bugged and you should ask for your money back.
No audio in MediaCenter - If you use passthrough sound, you need to set it in Sound Options in Settings, must use HDMI or SPDIF.
Do you have the exact same device and board version the firmware was made for, if not then maybe the audio chip is different in your device and there are no drivers for it in this firmware, thus no sound output.
There are more than 5 different board versions, so it complicates things if buying unknown devices, the device you get will have the same name and look the same from the outside but with very different hardware inside.
Hello,
Did anyone managed to get Ethernet working? With this kind of device network connection is crucial. And for me WiFi is some kind of semi solution, workaround, due to it's low speed and range. I'm at 2018.01.24 firmware and Ethernet is connecting to the router, it gets the IP address, but it has no transmission of data at all. WiFi works well, but for me it is unacceptable as long term solution.
As Found
H96 MAX RK3399 TV Box
PC Flash Firmware
File: http://geekbuying.mediafire.com/file/svbn26b13g4gl2c/H96_MAX_RK3399_20180502.rar
Flash Tool
Driver Assistant
Flash guide, please refer to: H96 MAX Upgrade All Steps
Note: This firmware is suitable for H96 MAX 6255 and 9377 WiFi module TV Box.
Source blog.geekbuying
There are currently 3124 users online. 0 members and 3124 guests.
