H96 MAX RK3399 Tv Box 4/32GB
Originally posted by LeKodeur View Post
For the ROM transfer software I used 'Rockchip Batch Tool v1.08' and for the drivers I installed 'Rockchip Driver Assistant v4.5'
Originally posted by trebor View Post
Are you getting enough power to the device to burn
I have seen that poor quality USB cables, using Front USB ports or laptops can give grief with failure to burn..
just thoughts...
Worse case do a warranty advise it failed during and update.
mine came with andriod 6. updated to 7 using this link-- https://www.youtube.com/watch?v=Vr4W-ufPD6o then found no sound and only resolution 864 x 864 in in the kodi display setting . after alot of around it didn't like my sony TV contection. Hoked into a samsung smaller tv and all good . (had a heap of resolution to pick from. Plugged the HDMI into my amp and all good with the sound on sony TV. Its trial and error. run the driver before using the factory tool. cool box.Last edited by scooter2014; 13 December 2017, 12:21.
Originally posted by HomesickSurfer View Post
Is it soft or hard bricked? I’m told these cannot be fully bricked. I’m still learning and relentlessly attempting to restore mine. I seem to be getting mine in and out of Loader and Maskrom modes
Originally posted by Danya View PostI also had the brick, the PC didn't see the console, restored in the following way: open FactoryTool combine the console with the computer, press the held-reset, connect the power and close the contacts after the circuit FactoryTool saw my box and I successfully flashed.
Thanx for the reply...what do you mean by "close the contacts"???
There are currently 1425 users online. 1 members and 1424 guests.
