H96 MAX RK3399 Tv Box 4/32GB
Guest
Originally posted by Hyster74 View Post
Originally posted by @curious1 View PostFinally got my box back up with the October firmware. To get the working Gallery app go to Apitode type in gallery. Third one down, 423k downloads, 4.6mb, uploaded by leecs.
Originally posted by @curious1 View PostAah-ha, thanks for the tip. Before I try the process again with factory tool 1.45 can anyone verify that the 180102 firmware fully powers down (not standby) with the remote? That is the main reason I'm wanting to upgrade. TIA.
Banzai please upload can't find anywhere.
https://mega.nz/#!dhwRmQ4L!oQb0EwfdB...emyLUn9IazetWE
Ok, I have never used Aptoide before so I downloaded on my desktop what I thought was the gallery you said to get but it seems this was just the aptoide installer that sneakily named itself gallery.apk. I then ran the app & searched for the gallery again & tried to install it but it says that a package with that name already exists. I even tried deleting the gallery in /system/app but now get package is corrupt when trying to install the modded gallery. Any chance you could let me know how to install it?
Guest
Finally back up with the newest firmware. Shuts down with my remote fine, just won't start from off with remote. Frustrating. BanziBaby, the Gallery I found is Gallery 1.1.40030 according to Titanium Backup. If I remember correctly I had to uninstall the old version before the updated one would install, some conflict. Backup your gallery first in case it gets botched.
Guest
Bunch of hits here. https://www.google.com/search?q=gall...utf-8&oe=utf-8 The icon shown here looks like the updated one in my app drawer. https://www.apkmirror.com/apk/lineag...-apk-download/
Originally posted by @curious1 View PostFinally back up with the newest firmware. Shuts down with my remote fine, just won't start from off with remote. Frustrating. BanziBaby, the Gallery I found is Gallery 1.1.40030 according to Titanium Backup. If I remember correctly I had to uninstall the old version before the updated one would install, some conflict. Backup your gallery first in case it gets botched.
Cheers for the info about the other galaxy, will backup the installed gallery with with both my backup pro & titanium backup to be safe before trying the one you suggest, many thanks again for your help.
Guest
Again, if I remember correctly... I think after uninstalling gallery and installing the new, it didn't work. So, I set up the new as a system app. Rebooted. Still didn't work. Installed as user app again. Rebooted, and the updated Gallery was working without issue. Android can be interesting sometimes.
Originally posted by @curious1 View PostAgain, if I remember correctly... I think after uninstalling gallery and installing the new, it didn't work. So, I set up the new as a system app. Rebooted. Still didn't work. Installed as user app again. Rebooted, and the updated Gallery was working without issue. Android can be interesting sometimes.
Guest
Great!Yeah, I like Nova better but Buzz at least works and is fairly customizable. And we have wallpapers!
Hi! I´ve received the H96 Max a couple of days ago. It runs correctly in a wifi way, but when I tried to use it with ethernet cable i realized that ethernet port doesn´t work. I updated to last rom but ethernet port doesn´t work.
Ethernet MAC is missed, there is no ip address...
Is possible to recover the ethernet MAC?
Thanks in advance
Regards
tv h96 max became brick,does not see the usb even when you press something in the audio output.
I tried a usb cable connected to the usb 3 tv box and the computer holding in the audio output.
I also installed the driver driver and 4.3 and 4.4 for nothing,only a red light lights up on the audio output
freakkid and Danya how did you do it?
"I also had the brick, the PC didn't see the console, restored in the following way: open FactoryTool combine the console with the computer, press the held-reset, connect the power and close the contacts after the circuit FactoryTool saw my box and I successfully flashed.how did you close your contacts?"
Please a video or a few more photos
Originally posted by catalin0231 View Posttv h96 max became brick,does not see the usb even when you press something in the audio output.
Used a paper clip and placed between the 2 contacts...(see post 249 for picture in red circle) while holding the reset button (in yellow audio output hole) and usb connected to computer and then connecting the power plug...this took several tries with the repositioning of the paper clip beween the 2 contacts. .play around with it...the point being the H96 Max can be unbricked!!!!Last edited by freakkid; 21 February 2018, 19:14.
There are currently 1085 users online. 0 members and 1085 guests.
