H96 MAX RK3399 Tv Box 4/32GB
@Denilsson78 have you disconnected the powercord?
did you press the reset button inside the 3.5 headphone jack, while connecting to the pc?
the windows drivers already installed?
what kind of male to male adapter do you use? did you connect to the blue usb port?
has your pc usb port more then 500mAh power output? a lot of questions...
Originally posted by DOMin8or View Post@Denilsson78 have you disconnected the powercord?
Of course I connected to the blue usb port. Don't now about the power output, but the computer recognized the box when I tried to update earlier. Device must be bricked.
Friends, hello ....
I installed the H96 Max 4G Ram, 32 GB Rom device google player storeden supersu.
My device did not turn on again (stayed in the MBOX post).
I had to install a new Software.
But what software I have installed does not work wifi.
I could not find the rk3399_hcy_7.1.2_528_40M_171016 software that your friend mentioned.
does this software solve the wifi problem? can you help me find the software ???
@ altincayir nothing spezial... lazy guys are not reading the forum... its postet a long time ago...
look here: http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3399-devices/660920-firmware-android-7-1-2-stock-alfawise-h96-max-rk3399-4gb-32gb?p=687210#post687210
posting #98
this is the oktober stock firmware. it works very well. i got no wifi with scv1. but with the oktober FW wlan is working well. but meanwhile, i decided to drill some holes and now i have LAN cable. without lan cable it was not possible to play 4k movies. now, with the lan cable 4k works well...
downloadlink:
https://mega.nz/#!ck5TzbiL!3CDvVHLF9...hjw6NDEYOs8j6U
i dont remember if the factory tool was inside. i flashed it with factory tool 1.44
There are currently 1695 users online. 0 members and 1695 guests.
