H96 MAX RK3399 Tv Box 4/32GB
    Originally posted by BidonX99 View Post
    The profile @L5.1 10-bit x264, declared by the Rockchip Co., is not play on any box with RK3399.
    Maybe in Nougat works, but, most likely, and there also does not work.
    Can you post a test video then I can check on RK3328, RK3399?
      Format profile: High 10@L5.1
      [Coalgirls]_Sword_Art_Online_(1920x1080_Blu-ray_FLAC)
      1. test [Coalgirls]_Sword_Art_Online_(High 10@L5.1 1920x1080_Blu-ray_FLAC) 1.2 Gb
      2. test SteinsGate_part1_High 10@L5.1_x264_10 bits 574 Mb
      test files:
      or cloud:
      https://cloud.mail.ru/public/8CY4/P7zJ55MmU 1.2 Gb
      https://cloud.mail.ru/public/J2qe/PU6j9Z8Bc 574 Mb
      also here:
      http://rockchip.wikidot.com/forum/t-...ot-work-rk3399
      https://twitter.com/IloveRockchip/st...64919296573440
      [email protected] (RKMC) - not responding
      Profiles 4.0-5.0 (10-bit x264) - work in the HW (Y8, stability did not check).
      Profile 5.1 - does not work (Yundoo Y8 & etc. box's, Android 6).
      Yundoo Y8 A6 [RK3399]
        dl
        3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
        CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
        Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
        Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
          I am using the custom rom, it seems that it is android 6.0 and not android tv. Playstore continues to be a problem, many apps could not install, have to use apkpure.
            My H96 MAX picks up wifi G only no N no AC at all WTF is anybody else having wifi problems ?
              please can any one help ans, I wants to FORMAT MY H96 MAX and re install 7.1.2.firmware bcs my box has no sound. but problem is when I connect usb to usb tool .my box not recognise. I mean not detect any boxc? please can you tell me which software I used . my laptro has windows 10... please reply
                please can you send me where should i download all driver, usb to usb tool and firmware plz
                  i am trying to install on from my laptop windows 10, But when i connect my h96 max nothing found?
                    Hi atiq33 ,
                    the Flashtool you can download here , same with Drivers, but to know what Rom
                    you need we need a Picture of your PCB , it looks there are different Versions of this Board . After that
                    we can guide you to the right place .
                    What do you mean with No Sound ???
                    greetings
                    gefattern
                      i purchased H96 MAX ROCKCHIP RK3399 4GB AND 32RAM. BOX. i tried all setting but no soun/audio comes from my box. so decided to contact seller, they send me burning usb tools and firmware downgrade to 6.00.. idownload all on my desktop laptop win10. but when i follows instruction my H96 MAX not found or deduct. .i read somewhere i needs windows driver for rockchip too?
                        Atiq33, have you tried this one? https://youtu.be/vzBdgnNGeGw
                          thanks , i done exactly same, but i dont know why my H96 MAX NOT found , when i connect with tools , its not showing any sign of connection or port , thats why its not uploaded into my receiver..
                            Hi atiq33 ,
                            sorry i was on the wrong Way with your Box , RK not AL , all this bricked AL Devices makes me a little ... ,
                            please download Batchtool 1.8 and AndroidTool 2.35 and RK Drivers 4.4 , install Drivers (Admin) and
                            look here :
                            http://ugoos.net/blog/rockchip-firmw...flashing-guide
                            if this dont work :
                            http://ugoos.net/blog/reflashing-in-...device-bricked
                            if something unclear ask . Do you have the right ROM ???
                            greetings
                            gefattern
                              thanks gefatten ROM you mean firmware i download version 6.0.0.. but first i download yours batchtool 1.8 and andro 2.35 rk driver 4.4. and comes back to you .. are you in uk gefattern?
                                Hi atiq33 ,
                                i am from good old Germany .
                                Did you already tried anything ???
                                greetings
                                gefattern
