H96 Pro Plus short pin unbrick help
This thread was a great read. I was able to take in most of it, but I must admit some of it went right over my head.
Originally posted by Flash125 View Post
Hello,
I have a very big problem, my box tv no longer works
I was flashing the firmware to my H96 Pro Plus 3go DDR4 / 32go with Burn Card Maker 2.0.2 and forgot to uncheck the erase bootloader box. I started the update then the box went blackscreen.
Now the blue light is stuck on and it won't do anything.
Can't even put it in recover mode.
Any help would be greatly appreciated.
Sorry for my english
ThanksBeelink GT1 Ultimate DDR4 / 32go
AlfaWise H96 PRO+ DDR4 / 32go
twedie read post #2 in this thread...your post is almost exactly the same as mine...Don't give up hope I got mine fixed using the method in post #38 but I had to use a specific USB 2.0 cable. Type A male to type A male about $10. I could not get the box to recognize the SD card I was using after I flashed the first time.
Also make sure you download and run Malwarebytes. There is an app on there that it will catch and delete that interferes with the wifi. (Supposed to be wifi update, icon is green with arrow pointing up...don't run it.)
Originally posted by Dweezle View PostI had a question I hope someone could help with. I have an H96 Pro Plus box the CPU is a S912 3GB RAM 32GB of storage. It is bricked and one other post (http://freaktab.com/forum/tv-player-...k-s912-h96-pro) asked the same question. Which pins would you short to try to recover form the bricked state? A person suggested that pins 5 and 6 on the left side but it doesn't appear that anyone confirmed that nor did the original poster state if it worked. Here is a pic of my chip (if it helps) any help would be greatly appreciated. Forgot to ask, what is the procedure? Short the pin then plug in power? Until it boots? Do you hold the reset button? Thanks again.
Hi basille
Start usb burning tool, load the image, press start.... Then connect your box.. The flash process should start automatically..
On the H96 Pro+ its enough to connect the power supply and usb cable (otg port) simultaneously... (no need to push the reset button)...Beelink GT1 Ultimate DDR4 / 32go
There are currently 2611 users online. 0 members and 2611 guests.
