H96 Pro Plus short pin unbrick help
Hi guys, hopefully someone can help me...i have the same problem, i was trying to update firmware using sdcard and box is bricked now..nothing on screen, i tried most of the steps in this thread with no luck...im stuck at 2% with some DDR error...any idea what would be the problem? greatly appreciated! thanks!You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by rafikiHi,
when getting this error, is your box connected to the power supply?
I'm getting the same error only when power supply is disconnected.
BR
Did you solve your problem? I contacted bangood and they said to try a new power supply. Not too sure about cause I know the device is bricked and not a power issue.
Any thoughts?
Thanks!
Once you are in a recoverable state, try this to restore OS
New USB Burning Tool v2.0.9 - https://mega.nz/#!U9QkgKbR!k-x9hAh8d...stnoDbOfOGxHZo
Firmware - https://chinagadgetsreviews.com/download-latest-android-7-1-stock-firmware-h96-pro-plus-tv-box-2.html
USB Burning tutorial: https://www.youtube.com/watch?v=tcZSiNVGihw (This one shows the GT1, but should be similar on other devices, just find your reset hole)
Be sure you have a proper USB to USB Cable to flash with, or it wont work.
Originally posted by twedie View PostHi Salamons
Your Box isn't bricked
Use the firmware Beelink GT1 Ultimate SCV1-ATV DDR4
http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4
The box H96 Pro+ is DDR4?
Tutorial the flash
Use Windows 7
Instal USB Burning Tool
On your computer, go to C:\Program Files\Amlogic\USB_Burning_Tool\WorldCup_Device.
In that folder is an exe file named, "InstallDriver.exe", run that, if you get permission dialog popups, allow them.
For Burning Tool Download and install this file into your burning tool Licence directory before starting the burning tool.
c:/programfiles/amilogic/burning tool/licence
https://www.dropbox.com/s/8gwrcd6d43t6pqj/mac_ether.ini?dl=0
Restart computer
Disable Protection Virus
Start usb burning tool
Load the image Beelink GT1 Ultimate SCV1
Then connect your box its usb cable (it's USB near power supply )
Then connect your box its to the power supply
Push the reset button.
Press start
Enjoy
Originally posted by Flash125 View PostThanks Aut0mat3d for your reply. I really appreciate any advice I can get. This will lead me to other places I can investigate.
I'm not very computer literate. I don't even know what TSOP stands for but I'll find out.. I'd need to know exactly where I would short them out before I could even try it.
Originally posted by marcoscreiodeus View PostYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello Guys
Im sorry but im a newbie on android box
and sorry for my bad english.
I have a very big problem with my AndroitBOX
I just can not find any working frimware for my box I can not flash the frimware/box
The Box is not Booting
i can not flashing with SD card becouse i see nothing on the my TV HDMI is not connecting with box ( Signal Fail )
Who can help me and give me Tipps ?
or do I have to order a new BoX?You may only view thumbnails in this gallery. This gallery has 7 photos.7 Photos
Try thismore http://4pda.ru/forum/index.php?showt...ost&p=66468620
There are currently 3230 users online. 0 members and 3230 guests.
