H96 Pro Plus short pin unbrick help
Originally posted by pulesky
I can flash using your method, but when it's finished I can see the superceleron android picture but nothing append... It's freeze on picture.
now it's better, I've an image and see the green android bar .Before flashing with sd card I was flashing with usb cable but never see h96 Pro picture or superceleron picture...only blackscreen
an idea to fix my issue?
Sent from my Nexus 10 using Tapatalk
Hello
I have a bricked H96 Pro Plus. The led lights permanently with black picture. No signal on HDMI.
I have read the posts here. I do not know exactly what you do with the pins.
Do I need to solder wires there? Then switch to Ground? I have a Samsung NAND on the board. Which pins do I need with the Samsung chip. 3GB Ram 16 GB rom.
Until now I have tried with USB Burning Tool the unbrick. But I always have an error at 7%.
I also have questions about the tool. Do I need separate files for each firmware in the license folder?
I hope you can help me and I understand the approach.
Regards
Regards
Sent from my SM-N9300 using Tapatalk
Originally posted by hcardoso483 View PostDont short the pins you dont need that just use stock rom and flash it as tooth pic method with the burn card stock rom and you'll be fine disconect the hdmi cable during.g the process
Hello
A few info about my box. Purchased in China. Supplied without function. Only the blue LED is permanently on. I had a loss of 10 Euro €. I do not know whether the box has a defective hardware. At the bottom of the board are 2 stickers. One with the MAC address 78: C2: C0 etc. The second sticker: CZ / 3G + 16G + 9377 JOB 20170117.
On the main side of the board: CZ-S32-V3 (DDR4) QL 1707
2xRAM 6NB77 D9TGG together 3GB
ROM Samsung 543A KLMA626EAC-B001 16GB
WIFI Fn-Link 8223A-SR F02021 1708
4x USB on board
I have tried a firmware. With USB Burnig Tool max. to 7%. With the SD Metode is nothing. The box does not boot from the SD card.
Great question now. What firmware should I still test.
Regards
Originally posted by pitarrus View PostHi guys, finally I could repair the brick of my TVBox following your advice the problem was the USB cable that has to be like the one we used for data, so I built one that had at home with their respective splices and Windows 10, I detect perfectly, I already have another TVBox new thanks to the advice of this chat. Thank you, thank you.
Originally posted by blueprintdk View Post
Is the cable you made a crossover cable or do you connect + to + / ground to ground / data + to data+ and data - to data - ???
Hello
I have this model S32-V5 (LPDDR3) 2017-08-29. I changes the power, the USB cable and i have the same problem. Stop at 2%
I use USB BURNING TOOL 2.1.2 (with cable + to + / ground to ground / data + to data+ and data - to data) and i have this error message in LOG
[23:50:58 854][HUB2-1][Err]--[0x10105004]Romcode/Initialize DDR/Read initialize status/Error result
[23:50:58 854][HUB2-1][Inf]--Close device handle 0x000003b0
[23:50:59 021][Global][Inf]--Catch DBT_DEVICEARRIVAL
[23:50:59 021][Global][Inf]--Scan usb device
[23:50:59 021][Global][Inf]--Aml scan WorldCup Device
[23:50:59 023][Global][Inf]--Host: Contrôleur d’hôte amélioré USB à circuit microprogrammé Intel(R) de la série 5/3400 - 3B34
[23:50:59 023][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b34&subsys_2a9c103c& rev_06#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
Can you help me ?
Thank's a lot
Bye
Originally posted by Salamons View Post
There are currently 3353 users online. 0 members and 3353 guests.
