H96 Pro Plus short pin unbrick help
Hello pitarrus
You have W7 or W10?
On your computer, go to C:\Program Files\Amlogic\USB_Burning_Tool\WorldCup_Device.
In that folder is an exe file named, "InstallDriver.exe", run that, if you get permission dialog popups, allow them.
For Burning Tool Download and install this file into your burning tool Licence directory before starting the burning tool.
c:/programfiles/amilogic/burning tool/licence
https://www.dropbox.com/s/8gwrcd6d43t6pqj/mac_ether.ini?dl=0
Beelink GT1 Ultimate DDR4 / 32go
AlfaWise H96 PRO+ DDR4 / 32go
Hi Salamons
Your Box isn't bricked
Use the firmware Beelink GT1 Ultimate SCV1-ATV DDR4
http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4
The box H96 Pro+ is DDR4?
Tutorial the flash
Use Windows 7
Instal USB Burning Tool
Restart computer
Disable Protection Virus
Start usb burning tool
Load the image Beelink GT1 Ultimate SCV1
Then connect your box its usb cable (it's USB near power supply )
Then connect your box its to the power supply
Push the reset button.
Press start
EnjoyBeelink GT1 Ultimate DDR4 / 32go
Tutorial the flash
Use Windows 7
Restart computer
Press start
Enjoy
There are currently 3071 users online. 2 members and 3069 guests.
