I would really appreciate some help or advice please Guy`s.
If there is another method to install this OTA update to the box......? Box is loaded ATM with SCV4-Test1-Blue-PCB-H96ProPlus and all is working fine...........Just can`t get this OTA update file to stick....So I need to know of an other methods to install this file as I have exhausted all my avenues and need fresh insight and impetus.
I was thinking of installing this build in increments of versions released ?
(Not seeing any OTA releases other than the 2 main files for Blue PCB boards on main OP`s 1st page post)... so as to see if this works to get me up to the latest in OTA updates ....would this be possible ? Sorry for the noob questions....But please remember I am relatively new to installing these OTA updates ...That`s not to say ..I don`t know what I am doing....quite the contrary......I am very tech savvy ...Just need a little helping guidance ...Please guy`s....I ALWAYS follow tutorials or instruction to the tee......So ...there must be just a slight glitch in my works somewhere which I need to iron out .....Hopefully.
Thank you for any help or advice you may offer.
Best Regards,
Edit Update:
I am absolutely shocked that this type of this happens...... The problem I was experiencing was I believe some sort of nefarious corruption on the download zip OTA-SCV7A-A7.1.2-x64-Alfawise.H96.ProPlus file from Google browser..... I am 100% sure.
I had this file downloaded yesterday and did the full MD5 check ...Everything was fine after numerous failed attempts to get this OTA update to stick...even though I knew I was doing everything correct.......it still would not work.
I spent many hours of F@@king around and trying different methods ....All of them failing...I then decided to re download the file again...Same file from Google and experienced the same problems....Which caused more stress, heartache. and pain.
I took a few hours rest to clear the grey cell (not many left after f@@king with this box) and gave it another bash continuing where I left off hours earlier.......The same garbage and pain..
I was Actually about to call time for today....Then I decided to download the OTA-SCV7A-A7.1.2-x64-Alfawise.H96.ProPlus file again
But this time I used Microsoft edge browser and once I had set up everything to. decided to give it another bash with this file.
BOOMIO!!! it installed and loaded fine 1st go and I had finally rid the Android splash screen freeze that had been plaguing and tormenting me for so many moons.
Method used: (which had been performed numerous times previous with nefarious google zip without success)
I place the full Zip OTA file on USB FAT-32 Defaults formatted in windows 10 Pro. Then Booted to TWRP recovery via the Recovery button power method and placed the USB in USB OTG port in the Android Box.
Brows TWRP Select drive and load USB ZIP ....I had to use a USB Mouse to swipe to install and TWRP did it`s magic.... I then swipe again to clear cache davik etc as TWRP recommends with prompt and then it rebooted and the Box booted up and installed the updates with Android logo icons.
.gif)
I can now eventually set this box up for my Daughter ......Dam I actually purchased this for her nearly 2 Christmas ago and still had not set it up for her
.gif)
I am quite sure this box with the Superceleron ROM will feed her needs and I can Only thank the creator for his Outstanding work and contributions to the scene. A Big Thank You Sir.
1 question: I would like to ask people is....What the best way to create a full backup image ? Once I have it setup as I need...Possibly TWRP ? Any feedback would be most welcome.
Thanks Guy`s ...I `am off to recharge and recoup what Brain cells I have left after this marathon tussle.
Best Regards,
