any chance to get the Widevine files from that device and implement it on our device in the next rom?
chenrp
Could be built in, but (un)fortunately isn't, so You have to user 3rd part methods. There is Network Speed Indicator Xposed module, which only purpose is showing network speed, but it seems to not work on 7.0+.
As for the rest than I don't see point in adding this two things. Most people doesn't change background to often, and even if more preferable is static non-auto-changeable wallpapers or LWP.
And launcher is something everybody should add by themselves - I understand stock one or Pixel Launcher, but any other is just an user's choice.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
John561
Just checked it myself and ADB over WiFi is working fine.
However my Box is rooted, so I used Terminal Emulator to set up ADB at 5555 port. This way I didn't have to use any drivers.
Just this 4 commands in TE:
Code:su setprop service.adb.tcp.port 5555 stop adbd start adbd
Code:adb connect 192.168.0.X:5555
superceleron in the 4K mode cursor is so small and youtube crash after choice above 1080p quality
There are currently 3391 users online. 0 members and 3391 guests.
