Originally posted by BangBang View PostOTA update link doesnt seem to be working for me. Keeps telling me to disable adblocker. There is no adblocker running
Updating is covered throughout this thread but here's an outline of what you need to do. I'd also recommend beforehand taking the time to watch a Youtube video on using TWRP.
Confirm your current firmware version against SuperCeleron's 1st page post. Ideally you need to be on version SCV4 and if you are it's fairly straightforward :-
Download the OTA version applicable to your TVBox (Green or Blue PCB). Do not unzip the file.
Copy OTA zip file to root directory of a MicroSD card (FAT32 format) and insert in TVBox
If you've a USB mouse to hand now might be a good time to plug it in to a spare USB port. It'll make for easier navigation in TWRP.
Boot TVBox into recovery mode (Power up whilst holding down reset)
TWRP should open.
Browse to update via zip and point to theOTA zip file on your MicroSD card.
Reboot once it's finished
Choose your launcher
TWRP's safer and provided you're backing up, there's probably less chance of bricking.
Hope this helps.
Finally just a shout out to SuperCeleron to say thanks for all the time and effort he puts in to updating and compiling H96Pro+ firmware. Much appreciated.
hello how can i know if my h96 pro plus is compatible with this rom? i dont know that stuff of "wifi chipset, dd3 etc" sorry im a noob my tv box is this: 3gb ram 32gb rom https://es.aliexpress.com/item/H96pr...311.0.0.vqrMu1
nicoga97
Could You make picture of the other side of the board? There is the name of it. You would have to take it out, so do it carefully to not break the wire of the antenna.
AbeATV
No. For some variants (S32-V5 and V6, the TVBOX_V3.0, maybe other) there are official firmwares dated on December or November. So no, SC roms are not most up to date.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1413 users online. 1 members and 1412 guests.
