Originally posted by ch3mn3y View PostYes. TWRP can access files on the USB drive. Update app probably won't.Last edited by lyubodelev; 09 May 2018, 14:09.
lyubodelev
Really? I didn't have SDcard at the beginning (that's why I used USB Burning Tool) and Update app didn't see .zip with OTA on USB drive. That;s why I used (and recommend) TWRP.
It wouldn't be first time when I could reformat it and it would work, but now it's to late...ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostGood to know for the future. Would prefer to don't need it, as everything is working fine, but who knows? Thanks.
Then reboot in recovery and restore from backup.
And you have a fully working fresh system!Last edited by lyubodelev; 09 May 2018, 19:04.
Hi all, i have a h96 pro+ 32gb but not sure what firmware i need? i am currently running kernel version 3.14.29 build NHG47L.20171010 test-keys, i want to upgrade the firmware at this one is constantly freezing up the box and locking up, i have to constantly pull the power lead and restart the device, it is driving me mad! Please advise any help will be greatly appreciated
Crusader007
If You want be sure which firmware is for Your Box, than You have to open it and look at it's PCB - name of the variant should be on the upper side of the PCB (one You won't see after opening it, only after taking PCB completely out of its case).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
As for official than look here: https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!Z6gTFC7A
There are dates, so You'll find latest one.
As for unofficial, there is this one and Android TV rom (both made by superceleron). Both should work without the problems on S32-V2.2.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1506 users online. 1 members and 1505 guests.
