doing in this way what changes? do I have to reconnect the hard drives to the box with the vlc open?
More like use PC to check them for errors. Android is limited in that matter.
Are both drives connected at the same time? Do they have extrenal power supplies or are powered from USB port? Did You try to connect only one of the drives to check if than it would work better?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Flash SCV4 again, check how it works, if it's OK, update to V7A, if not use stock. It may not be the best, but anything working is the best.
Or, if You just use Kodi, flash LibreElec. Or even move to some Linux distroALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by lucabis View Postwhat do you advise me to do?
Attach these hard drives to the laptop (PC).
Make the content of the drives part of your media server's library.
Install Plex on your TV box.
With Plex connect to your Plex Media Server.
Enjoy!
Originally posted by BrandoR View PostIs there a way to delete the default 2 home screen launchers? If I choose a different launcher as the default, occasionally the OS forgets and asks me which launcher I want to use...
BrandoR
With Root there is. I wouldn't remove them, but You may use app like Titanium Backup (Pro needed) oraz App Freeze (abandoned, but free) to freeze/disable the app. It will still exist, but won't be possible to lauch, won't use RAM and OS won't see it (so it won't ask You to choose it).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by BrandoR View PostIs there a way to delete the default 2 home screen launchers? If I choose a different launcher as the default, occasionally the OS forgets and asks me which launcher I want to use...You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
What launcher is that? Looks sweetLast edited by lyubodelev; 15 May 2018, 21:22.
There are currently 2466 users online. 0 members and 2466 guests.
