i saw now ... 64 bits
for those of you who have problem with update with usb burning tool, i manage to install scv4 with SD card maker.. i wasnt able to do it before because i was not on stock Android 7 version (was on 6), and after that it was the SD card itself (so please try with several SD cards) i was able to do it with a normal class10 16GB ADATA card ( kingston 8GB class 4 was not finishing install)..
Originally posted by mso07 View PostHi everyone
I bought alfawise last month however seems there are some differences from old ones
My have ZH-S912-TVBOX-V2.0.... older ones have CZ-S32-V2.2
My question is can I flash SCV rom on ZH-S912-TVBOX-V2.0?
Second question, after flash SCV4 how can I update do SCV7 if no OTA apears ... can I flash SCV7 OTA by twrp?
Hope can someone help, thank you very much
marco
thanks again supercel for the amazing work
Originally posted by pedropitt View PostTo upgrade, save the .zip to usb drive, enter TWRP ( clip to the hole and power ON).. an then install from there.. wipe cache and reboot..
superceleron I tried to install your ROM on my H96 Pro+ (purchased from GearBest recently) but always failed. Only until I unchecked erase bootloader the flash was successful. But after that, I tried to boot the box and nothing showed up on the screen. On the box, I can see the blue light n the box. I tried to flash the img again but now the USB burning tool cannot detect the box. Help!!!
marco
1) Externally in the box can you access the 4 USB ports ?
2) Did you flash the new box to SCV4 ?
3) Did you manage to upgrade to SCV7 OTA via TWRP ?
4) What alfawise model do you have, I thought AlfaWise H96 PRO+ only had 2 USB ports ??
I am asking this because I just ordered an AlfaWise H96 PRO+ 3/32Gb and I wonder if I will encounter the similar problems
ThanksLast edited by Alianato; 06 November 2017, 16:55.
Originally posted by martymoose View Postsuperceleron Mate fantastic work, hope you can keep it up
cheers
Glad you guys like it... and sorry to all for the lack of updates... but im really busy at work i almost dont have time to touch this, and when i a have some free time... im so tired of roms at work... that i dont want to touch on more rom's.. lets see if it slow down a bit at work so i can make some updates!
What updates are still required or is it just minor bug fixes? The speed increase alone makes a massive difference. Not sure how you achieved it but it works.Last edited by Modelman; 06 November 2017, 21:38.
translation: embrace from another portuguese guy, I use one of his roms, with the rgb_fix on a sony, with great result, good job!
I would be lost without this fix
all the best
Externally only 2 usb but more 2 inside
Have 2 boxs, alfawise S912 3Gb+32Gb, but one Oct 2017 with reference ZH-S912-TVBOX-V2.0....other from Nov 2016 reference CZ-S32-V2.2.
Can't flash SCV on ZH-S912-TVBOX-V2.0..... other one not tried yet
Hi
can you identify the diference of the two models without opening the boxes, I wouldn´t want to open mine
Hi, is there a way to check if we have a "genuine" alfawise H96 Pro+ ?
Knowing that would avoid loading superceleron rom into a non-genuine box, possibly bricking it.
It also could be of some help to know the identification of the boxes/clones where superceleron firmware works and the ones where it doesn't
thanks
There are currently 2127 users online. 1 members and 2126 guests.
