Btw i installed your rom on H96 Pro 2GB/16GB (NOT PLUS) and it's amazing , working so good . Thank you so much for your marvellous work.
Originally posted by Wsx View PostYou have to try to flash during reboot of box.
Also I bricked but this box can't brick so you have to be fast to run usbtools on reboot (in this time of connect to box)
Inviato dal mio SM-G935F utilizzando Tapatalk
Usb burning tool no longer detects the box. The start button remains grayed out all the time
used sd card to flash SCV4-A7.1.2-x64-Alfawise.H96.ProPlus
now, computer doesn't recognize, nothing on tv,
won't take a sd flash as far as i can tell
I managed to hook up an arduino as a serial ttl
got this
BL2 Built : 11:58:42, May 27 2017.
gxl gc3c9a84 - xiaobo.gu@droid05
set vdd cpu_a to 1120 mv
set vdd cpu_b to 1050 mv
set vddee to 1000 mv
Board ID = 1
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 816MHz - FAIL
DDR3 chl: Rank0 @ 816MHz - FAIL
DDR3 chl: Rank0 16bit @ 816MHz - FAIL
DDR4 chl: Rank0+1 @ 792MHz - FAIL
DDR4 chl: Rank0 @ 792MHz - FAIL
DDR4 chl: Rank0 16bit @ 792MHz - FAIL
DDR init failed...
Reset...
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0; EMMC:0;READ:0;0.0;CHK:0;
TE: 170461
any other info needed to help me?
It would be great if users who have the new H96 pro plus takes pictures on the motherboard that have issues flashing the rom. And pictures of a working motherboard to know the difference when users buy a H96 pro plus box so that everyone can see and use the correct rom without bricking the box.
Originally posted by nakti View PostIt would be great if users who have the new H96 pro plus takes pictures on the motherboard that have issues flashing the rom. And pictures of a working motherboard to know the difference when users buy a H96 pro plus box so that everyone can see and use the correct rom without bricking the box.
I would post a photo of my MB if someone is kind enough to guide me on how to open the h96 pro plus.
Originally posted by lkbfreak View PostWhile using the box for a two weeks with this rom I have some pretty frequent reboots and my CPU temperature is between 70 and 80 °C. What could be the problem? Should I reflash? And I have random Google play services stopping.
Originally posted by steve_eh View Postused sd card to flash SCV4-A7.1.2-x64-Alfawise.H96.ProPlus
got this
Board ID = 1
CPU clk: 1200MHz
DQS-corr enabled
DDR init failed...
Reset...
TE: 170461
Try to flash by usb burning tool this one...
DDR init failed...
http://freaktab.com/forum/tv-player-...787#post680787
tried 2 cables
reinstalling drivers
only thing I can get it to do is that bootloop i pulled off the serial connection
Originally posted by Modelman View Post
It's probably the high temps causing all the problems. 80c is not good for stable running you should be aiming for less than 60c.
Originally posted by mrpants View PostThin knife and take the plastic bit off the top..
Carefeully (ok with knife) i solved the logo plastic inlay from the top and then made only a small cut then by kinking i got the middle part out and used the adesive residues (rests) to glued the tips once more. Was very easy.
see my posting #95 here http://freaktab.com/forum/tv-player-...are-mods/page7
I made in 2 boxes and could decrease the temperature about 10 º C
Originally posted by tombraga View Post
i made nearly it without cutting with knife,
Originally posted by tampametal View Postsuperceleron does this work with the banggood version of the H96 Pro+?
There are currently 2255 users online. 2 members and 2253 guests.
