But i also have a M8S Pro L.... so dunno what to do lol i cant do both now so.. lets see!
I'd be curious to see V8 of the ROM. Got V7 installed and think it's an awesome ROM, a thousand times better than stock. I'm sure it must be frustrating dealing with the clones. People should just understand that they try the ROM at their own risk. If it works it works, if not then revert to a back up.
Originally posted by srafa007 View PostMine just died yesterday, I was using the remote control that came with it to shut it down. Now just the blue led flashes like Morse code and nothing on TV. I had 7A on it and it worked fine, tried to flash it back to SCV4 but I receive the DDR init failed, with different cables same error.
The people with bad power bricks should try hitting up your vendors for a free power supply. Especially if you suggest that you may go through Paypal(or your credit card purchase protection/charge back). Sadly the vendors got faulty stock...but they are still responsible for providing the product you paid for.
Originally posted by srafa007 View Postmany thanksit works.
ReaperMan Yeah vendors/manufacturers should respond for those faulty products, but entering a dispute with them and PayPal often results in returning the broken adapter /box, which surely is more expensive than the price of the box itself or purchasing a new adapter.
Originally posted by Vaizen View Post
By the way it "died" it is more likely to be the AC adapter that died. Few weeks ago mine "died" while watching some series the led was giving Morse code as you say but it was dimmed. Luckily some other people have reported AC adapters dying, so the first thing I did was getting a replacement. I purchased a 5v 3A and the box came back to life. No need to reflash.
My Vendor gave me a $10 dollar credit.
maybe you can figure this out superceleron
got a gamepad here
doesn't wanna work in android or in retroarch...doesn't seem to even register
heres the info on it
=========================== USB Port6 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 3-6
Properties : 0x01
IsUserConnectable : yes
PortIsDebugCapable : no
PortHasMultiCompanions : no
PortConnectorIsTypeC : no
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : USB Input Device
Device Path : \\.\usb#vid_0079&pid_0011#5&297258bb&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_0079&PID_0011\5&297258BB&0&6
Hardware IDs : USB\VID_0079&PID_0011&REV_0106 USB\VID_0079&PID_0011
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0014 (GUID_DEVCLASS_HIDCLASS)
Driver : \SystemRoot\System32\drivers\hidusb.sys (Version: 10.0.15063.0 Date: 2017-03-18)
Driver Inf : C:\Windows\inf\input.inf
Legacy BusType : PNPBus
Class : HIDClass
Class GUID : {745a17a0-74d3-11d0-b6fe-00a0c90f57da} (GUID_DEVCLASS_HIDCLASS)
Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Service : HidUsb
Enumerator : USB
Location Info : Port_#0006.Hub_#0003
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(6), ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(H S06)
Container ID : {c790d7b4-ca37-11e7-95a6-bc5ff4f9e585}
Manufacturer Info : (Standard system devices)
Capabilities : 0x84 (Removable, SurpriseRemovalOK)
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
Power State : D0 (supported: D0, D3, wake from D0)
Child Device 1 : HID-compliant game controller
Device ID : HID\VID_0079&PID_0011\6&379B9A&0&0000
Class : HIDClass
---------------- Connection Information ---------------
Connection Index : 0x06 (6)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x01
Device Address : 0x06 (6)
Is Hub : 0x00 (no)
Number Of Open Pipes : 0x01 (1)
Device Bus Speed : 0x00 (Low-Speed)
Pipe0ScheduleOffset : 0x00 (0)
--------------- Connection Information V2 -------------
Length : 0x10 (16 bytes)
SupportedUsbProtocols : 0x03
Usb110 : 1 (yes)
Usb200 : 1 (yes)
Usb300 : 0 (no)
ReservedMBZ : 0x00
Flags : 0x00
DevIsOpAtSsOrHigher : 0 (Is not operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 0 (Is not SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 0 (Is not SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x100 (USB Version 1.00)
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x08 (8 bytes)
idVendor : 0x0079
idProduct : 0x0011
bcdDevice : 0x0106
iManufacturer : 0x00 (No String Descriptor)
iProduct : 0x02 (String Descriptor 2)
Language 0x0409 : "USB Gamepad "
iSerialNumber : 0x00 (No String Descriptor)
bNumConfigurations : 0x01 (1 Configuration)
------------------ Configuration Descriptor -------------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x0022 (34 bytes)
bNumInterfaces : 0x01 (1 Interface)
bConfigurationValue : 0x01 (Configuration 1)
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0x80
D7: Bus Powered : 0x01 (yes)
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0x32 (100 mA)
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00
bAlternateSetting : 0x00
bNumEndpoints : 0x01 (1 Endpoint)
bInterfaceClass : 0x03 (HID - Human Interface Device)
bInterfaceSubClass : 0x00 (None)
bInterfaceProtocol : 0x00 (None)
iInterface : 0x00 (No String Descriptor)
------------------- HID Descriptor --------------------
bDescriptorType : 0x21 (HID Descriptor)
bcdHID : 0x0110 (HID Version 1.10)
bCountryCode : 0x21 (33 = US)
bNumDescriptors : 0x01
Descriptor 1:
bDescriptorType : 0x22 (Class=Report)
wDescriptorLength : 0x0065 (101 bytes)
Error reading descriptor : ERROR_INVALID_PARAMETER
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
bmAttributes : 0x03 (TransferType=Interrupt)
wMaxPacketSize : 0x0008
bInterval : 0x0A (10 ms)
-------------------- String Descriptors -------------------
------ String Descriptor 0 ------
bLength : 0x04 (4 bytes)
bDescriptorType : 0x03 (String Descriptor)
Language ID[0] : 0x0409 (English - United States)
------ String Descriptor 1 ------
bLength : 0x24 (36 bytes)
Language 0x0409 : "DragonWind Inc. " *!*CAUTION trailing space characters
------ String Descriptor 2 ------
bLength : 0x1A (26 bytes)
Language 0x0409 : "USB Gamepad " *!*CAUTION trailing space character
----- String Descriptor 0xEE -----
can't figure out how to get it working..it works fine in windows and linux and it works in retropie
i've been doing some research and it seems like xinput gamepads work ok in android but not directinput controllers? which im guessing is what this gamepad is
if you need any other info..let me know and I'll get it....
heres the keycodes from the gamepad
A=289
B=290
Y=291
X=288
R1=293
L1=292
START=297
SELECT=296
UP=0-127
DOWN=255-127
LEFT=0-127
RIGHT=255-127Last edited by gogeta; 22 November 2017, 02:11.
Originally posted by superceleron View PostEDIT: One more update...
Many Thks to my beta tester's trebor and scooter2014 !
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Hi thanks for the ROM everything works great except two bugs i found one is that the tvbox can't go to sleep and wake up again when i use the root menu it reboots only with soft reboot and makes soft reboot and with reboot shuts down and with shutdown shuts down, and can't wake up the box.. The only way to wakeup start up the box is with unpluging the power cable and replug it and the other issue is that the IR not working my original Remote Control from tv box not working
i am on the latest V7A i have the Green pcb and i flashed successfully the Green Rom
Thanks nikkpapLast edited by superceleron; 22 November 2017, 15:43.
Originally posted by gogeta View Postcan't figure out how to get it working..it works fine in windows and linux and it works in retropie
A=289
B=290
Y=291
X=288
R1=293
L1=292
START=297
SELECT=296
UP=0-127
DOWN=255-127
LEFT=0-127
RIGHT=255-127
Thanks nikkpap
hope this is the solution http://mxqproject.com/files/Remote-Config-File/
There are currently 1477 users online. 0 members and 1477 guests.
