OK i found in menu power key definition on definition is to sleep now if i change to power OFF when i want to power OFF with remote control no menu now apperead
only solution to take off the power cable and retry and at reboot sure in menu power key defintion
and for OTA update grrr the catastroph
i take my usb key with file File: OTA-SCV7A-A7.1.2-x64-Alfawis e.H96.ProPlus.zip
I choose on file usb this file i not coch wipe data wipe media and i click update
result that s reboot but nothing apperead on tv blacl screen not update and box there s no led at the fine 10 mn i take off the power cable i retry and horrible not boot nothing and nothing on tv but blue light on front
i try to boot in recovery mode grr nothing
is there s solution or all is lost and i must retry with usb burning tools
Hello
I' bought this h96 pro+ on gearbest
3g + 32g + 9377 20170926
Which rom should I use? Is possible update without USB? With SDCARD?
please somebody help me
superceleronLast edited by tribalito; 14 December 2017, 01:14.
yes choose the rom green pcb but it s more if you take ANDROID TV version on other post there a link
Download SCV4 GREEN PCB IMG:- DOWNLOAD HERE GREEN PCB SCV4 IMG 7.1.2
- MD5: E17A5C3B8AAE2E5053BC3077E14F874F
For ch3mn3y
I UNDERSTAND my mistake
i take file OTA here and i have place version rom android tv
then the good file is OTA-SCV4A-ATV-A7.1.2-x64-Alf awise.H96.ProPlus.zip
i retry now with good file sorry i go to the good post
dangchui Buddy but why i need to choose this firm? Is better than AlfaWise H96 PRO+ 3/16Gb - 3/32Gb - 3/64Gb - SCV7A 7.1.2 (DDR3/DDR4 and 9377 Wifi Chipset)?
Second question. After that i need to flash update for OTA?or only this firm?is possible with sdcard?
that s write on first page first SCV4 green with technic usb burning tools usb cable or with technic sd card and after install take OTA UPDATE SCV7A OTA or on menu android
at propos and you see this image
see this video for technic https://www.youtube.com/watch?time_c...&v=NtszyX0iwqw
Download SCV7A OTA:- DOWNLOAD HERE SCV7A OTA 7.1.2
- MD5: 920704AF654F78B8CC60A7A2821CE6D7
Download SCV4 BLUE (LPDDR3) PCB IMG:- DOWNLOAD HERE BLUE PCB SCV4 IMG 7.1.2
- MD5: 67D22C782DDCA083F297B98DA406ADE3
Install instructions:- Use usb burning tool....
Nothing to do with Firmware - Kodi- but when I do a music or video scan it locks up sometimes, so have to reboot, and do another. It's taking forever to catalogue my files as everytime it starts from "A" then checks if those have been added then when it gets to where it crashed last time, it continues.
Also how do you set subtitles on to only non English audio? For English TV shows subs still appear, I only want it for non English.
Shimon
Depends which one did You get. It's probably one of S32-V5 (if blue).
Best choice is to ask GearBest for firmware.
But not sure if they help You. I asked fo fw for V6 and I don;t get it, however they propose me 3 options: send it back, get back $20 in their wallet or $20 to PayPal. Not sure if it's better than firmwareALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 3022 users online. 1 members and 3021 guests.
