Thank you! By now I have backed up everything and read through maybe a third of the posts here. Sorry, I have one other question as this is my first time messing with firmware upgrades. It seems people are more likely to run into issues using the sd card option. So I decided to avoid that - I do have a cable, downloaded the burning tool plus all three images. My current version is android 6.0.1 on the device.
Could anyone please c&p the steps to get to the latest IMG, e.g. flash blue/green img first and so on? This might seem so lame on page 118, but I'd really REALLY like to avoid ending up with a bricked box I can't use anymore. Thanks, everyone and a beer will be definitely on its way once Nougat is up and running.
Originally posted by swabidooda View PostThank you! By now I have backed up everything and read through maybe a third of the posts here. Sorry, I have one other question as this is my first time messing with firmware upgrades. It seems people are more likely to run into issues using the sd card option. So I decided to avoid that - I do have a cable, downloaded the burning tool plus all three images. My current version is android 6.0.1 on the device.
Originally posted by matt59631 View Post
goto this link and download the tools and follow the instructions on the page(just use scv4 instead of the firmware on this link). use this guide for scv4 ....after u have scv4 up and running then go back to ur computer and download scv7 ota (do not unzip it) just put it on an empty sd card then put the sd card in ur box and copy the scv7 ota to the download folder after that shut the box off unplug the power cord only use a paper clip to push in the tiny button on side of box n while holding the button with paper clip plug power back on continue holding it until twrp screen appears then click install then on next screen on the left hand side click download folder then click scv7 ota file and then the box will do the rest
Thanks - so you're saying to combine both methods? First for the scv4 you are saying to use the burning tool and a male to male usb cable and once that worked switch over to micro sd card with scv7?
That's what I understood, unfortunately, my windows doesn't recognize my device (in recovery mode) in the burning tool. I have the drivers installed and tried every possible combination. Maybe my cable is faulty.
So after an hour trying to troubleshoot that I gave up. No idea why the box doesn't show up connected in the burning software.
Originally posted by swabidooda View PostThanks - so you're saying to combine both methods? First for the scv4 you are saying to use the burning tool and a male to male usb cable and once that worked switch over to micro sd card with scv7?
Originally posted by Golani4455 View Post
You need to upload the scv4 file in burning tool once checked file is complete you need to click run then connect the USB to the box
It sucks.
@ superceleron,
I wondered about your opinion of WireGuard VPN kernel implementation.
More secure? Less code= less buffer= less heat=faster? I do not understand if this is a good direction for China Boxes or just smart phone roms.
@ swabidooda,
You have the process correct, USB Cable for IMG flash, then, SD card for OTA zip flash/update.
I'm quoting myself here, but if it helps...maybe an admin can rewrite a better sticky in the s912 or Alpha forums?
More than likely it is your friendly Windows causing grief.
Anti-virus/firewall software combine with O.S can cause grief. Disconnect and close/force stop background apps...
Try to install the World Cup drivers again...don't reboot. Make sure to use USB port(OTA) on your China Box.
or
Install World Cup drivers and reboot, might work.
or
Go into device manager and find World Cup drivers and make Win 7 compatible. Try to flash..or reboot and try to flash.
or
Go into device manager and uninstall World Cup drivers...reboot and re-install drivers.
or
USB mouse may interfere with Amlogic Burn Tool(My laptop). Start up Burn tool and remove mouse and connect China Box to flash.
If you have installed multiple versions of Amlogic Burn Tool, it might be best to uninstall and go into folders to delete leftover files...and drivers.
Windows OS has gotten so user friendly since Win 7 that it is increasing difficult to use or support.
G-Luck,
Reap
I always hold down the reset button then plug in the power cord then plug in the usb cord (all while holding down the reset button) then ull hear a sound from the computer once u hear that sound its connected n then u can let go of the reset button then open world cup then go through the steps then open batchtools and load the firmware and click run......(the last h96 pro + box i flashed I had trouble getting it to connect I hold reset button then plug in power cord then usb n had no connection I just unplugged the usb and power cord n started over after 5 or 6 tries I got it still don't no why I had that issue but just keep trying and try different usb ports on the computer
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Thank you for for sticking with me - still doesn't work, but at least I got ONE step further. I actually got connected with the reset button advice, but once I run the flashing process I got the error you can see in the attached pic. Any idea what's the issue now..?
The Above worked for my R-TV Box S10 just another s912 player that also works with this Firmware.
Just got my H96 pro+ up and running with the latest version of the super celeron rom. So far its great and much better compared to what the box was running when I first got it. My question is the power on/off. I can turn the box off with my favormates air mouse remote control but I cant get it to turn the box back on. I have to unplug the power and plug it back in to get it back on. Is there a fix or setting I need to change? Thank you.
There are currently 1601 users online. 1 members and 1600 guests.
