I want to extract the original remote.conf from the original firmware, is this possible?
Originally posted by Alianato View Postsuperceleron is there a way to mount/edit an image (img) file and to extract a file from one of the partitions?
Using mount command in Terminal (with Root) doesn't work?
Code:mount -t [B]X[/B] -o loop [B]XXX[/B].img /[B]Y[/B]
Is it this file? Had already unpacked system partition (from stock's TWRP backup). It was in /etc folder.Attached FilesALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostUsing mount command in Terminal (with Root) doesn't work?
I was playing with AmlUITool v1.6.2 but I suppose this is not the one I should use because it only loads zip files.
Is the "mount -t X -o loop XXX.img /Y" a linux command? Mostly I am using windows but I also have a machine with mint installed
thanks
Alianato
It is, but it also works with rooted Android. It may be enought to use mount -t XXX Y. Without "loop" and "-o". Depends if it's loop device.
You can try this (old) guide: https://forum.xda-developers.com/gal...m-img-t1081239
And use Cygwin to use Linux commands on Windows.
RamonSK
I believe it may be wrong mapping. I don't think Android lets You to remap buttons of the connected keyboard, but You could remap (for whole device) Context button as Home one and than it will workALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
RamonSK
Originally posted by ch3mn3y View PostCorrect. You can use Update app as well, it will automatically boot the TWRP and flash the chosen .zip file.
However if You want to flash Root (MAGISK or SuperSU) after V7A, than its easier to boot to TWRP with the pin (paperclip) method.
Additionally it gives You a possibility to make backup of V4 before flashing V7A update. If anything bad happens (shouldn't), than You will be able to restore that backup (as long as TWRP will boot).
Since I was not able to see the recovery screen on my tv (using paperclip)
To update scv4 to scv7 ota
I ve copy the zip file into sdcard(without anything else ) .. use ota update with local file and it works
Then I try the paperclip to see TWRP and it works
One others question how do you configure lighthome launcher.. since I am not using KODI
thanks
yann06
I don't think You can change to much with this Launcher, only add/remove smaller shortcuts. I found HALauncher as best one (for me). It's stable, but I found 2 bugs:- If You press Back to much it Force Closes (but it's launched back as I freezed other launchers),
- Sometimes apps shortcuts on "mine screen" loose their icon (there is pixelated Android) and have to be removed and added back.
There was guide somewhere. However I cannot find it now.- Download both SCV4 and update (SCV7A).
- Unpack both .zip files.
- Power off the Box.
- Connect male2male USB cable to Box.
- Install USB Burning Tool
- Launch it.
- Click File->Import image and choose SCV4-Test1.img.
- Connect male2male to the PC. Wait for drivers to be installed (it will be WorldCup device or something like that).
- Disconnect it.
- Connect again.
- Click [Start] in Burning Tool.
- Wait.
If it won't help, write about it.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
superceleron your blue rom version, works with the Tanix TX9 Pro/Vorke Z6 Plus, however wifi and bluetooth are broken although the chip is the same "WiFi Chip QCA9377"
Could you adapt your blue rom to this boxes in order to have wifi/bluetooth working?
thanks
There are currently 2926 users online. 1 members and 2925 guests.
