Well update to OREO dont depend on me, but 1ยบ public betas should start surfacing in February
nprev917
AOSP/CM/LOS are not same as Android TV. Totally different platform.
That's way there is already Android 8.1, but Android TV 7.1.2.
Additionally it's rarer updated with security patches + we don't have official build and/or Project Treble, so even updates with this patches have to be compiled by superceleron (or other dev, but we have only him).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Not sure if it's been mentioned, but I discovered that the box can be turned off and back on with remote using SCv7a. Just change the power button allocation to power off instead of sleep in the settings. It seems the sleep function doesn't work but the power off function works fine.
Edit: reboot also works well now as a result.รยLast edited by Mandrake; 13 December 2017, 09:18.
Installed this ROM without a problem, and the update. A couple of things
1) It's not rooted, is it easy to do this? I've installed KODI from play store so I guess no need for the bunded FTMC?
So either uninstall from system, or just freeze it. Want to freeze stock browser too
2) The other launcher (myeos) or something called like that has no text under the icons, how do you add it
3) How do you customize homescreen, remove FTMC and browser from desktop?
4) Can I control Kodi on the alfawise, from a mobile phone? That way can play music without needing the TV to be on
5) I've got a UK keyboard, when I enter @ it enters another symbol like $ or something, I've changed system to UK and still the same
Also stock firmware allowed me to connect to Samsung 24" 1920x1200 monitor HDMI-DVI, however with Superceleron I just get garbled image and it's all green, you can't see a thing, so had to set it up on the plasma (not ideal) Is there a fix to this?
fatbottom
A1. Flash MAGISK through TWRP. That's it
A2. -
A3. I don;t think You can.
A4. There should be some apps for that. I'm looking for Unified Remote server or Android myself.
A5. Change Android keyboard language, not just system one.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by fatbottom View PostInstalled this ROM without a problem, and the update. A couple of things
I've got a question. I tried remapping my gamepad, by going to device-system-user-keylayout and then editing the file for my gamepad. I've correctly mapped the device. I've also tried gamepad tester to remap. Yet when I go into games Asphalt 8 and skate party 3. In both games it defaults back to what it always is. Seems remapping has no effect. How do I make the remapping permanent?
There are currently 5212 users online. 0 members and 5212 guests.
