Hello, sorry my english ..... ingles of google translate ... with the v4 no step, but with version v7 yes, I enter in recovery mode, my tv, does not emit signal ... it has a year old lg uhd 4k, only happens in recovery mode ... otherwise perfect!
edit
connected pc monitor, does not pass, tv if ...
Originally posted by skiper View PostHello, sorry my english ..... ingles of google translate ... with the v4 no step, but with version v7 yes, I enter in recovery mode, my tv, does not emit signal ... it has a year old lg uhd 4k, only happens in recovery mode ... otherwise perfect!
edit
Es un problema del TWRP. no es compatible con resoluciones superiores a 1080p. Intenta con un tv o monitor de menor resolución.
edit: thanks 1080p ok!!!
comes something similar to ultra deep color, I already deactivate it
on block 720. 1080, I have other devices in 1080 and all ok, it is not that you see black signal .. it is not that it does not emit anything, it detects the TV, but it does not emit, then I will try to change in tvbox 1080 and restart .. but this did not happen with version 4 V
then I have seen, that on the monitor screen, it looks like interferences ... this did not happen with version 4Last edited by skiper; 06 December 2017, 22:31.
Hello
I have bought the H96 Pro+ 3gb/32gb/Amlogic S912/Android 7.1.1 (No Alfawise logo) from bangood. PCB is blue, with S32-V6 (LPDDR3) 2017-09-05. Can i install SCV4 BLUE (LPDDR3) PCB IMG then update via recovery to SCV7A OTA? I reed forum http://freaktab.com/forum/tv-player-...-hardware-dead, and there is nothing said that with blue img it succeeded.
Anyone try this firmware with U2C Z Super? Seems nearly identical to the h96 pro+. 3gb/32gb DDR3 s912 processor and 9377 wifi chipset. https://www.amazon.co.uk/Android-U2C...ds=u2c+z+super
Hey guys, I own the Vorke Z6 plus 32GB model and unfortunately bricked it trying to upgrade using the Micro SD card burning tool. By failing to uncheck erase bootlaoader I bricked the device. I have used short pin method to reconnect to my pc then flashed this image file "SCV4-Test1-Blue-PCB-H96ProPlus" thank you developer. The challenge I have now is that wifi doesnt work as stated in the post and can't get any other firmware to boot and I've flashed a number of device specific firmware only the test image allows me to boot. Any help would be greatly appreciataed? Thx
I have modified the FTMC logo in Lighthome launcher with 3D KODI logo. Here's the link if anyone like to try https://goo.gl/SnxqKe
install/uninstall no problem on top of default Lighthome launcher.
Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
Originally posted by velqn View PostThat’s cool!
hi can I only change the launcher background?
tnx
YES if you want to choose from 4 backgrounds provided with the launcher. if you want other then that have to decompile apk-RK3368 CSA91/R8/R68 V2, V4
Hi ppl i was getting some troble with my box, all was working but kinda laggy, today i installet xposed frameworks and gess what now i know what SC have build a real awsome masterpice, i know that he still did not fi ish acording to what him self has tellong us but with the framework i it it really takes it to another level, my box is some kind of clone i gess coz it never worked the way thay i read ppl talking about but now it does, so this xposed frameworks is defenetly a plus, i installed the version 3.4 of the installer and the completion is on its own, if i thought this was a great work know i thing this is gone for the next level, Thanks Superceleron and Thanks Rolvo69...
Enviado do meu GT-N8000 através de Tapatalk
Originally posted by MandrakeOk so this might be a stupid question, but how did one copy and paste from chrome? I can highlight what I want to copy, but long press does nothing. Tried cntrl c and v. That does nothing. Any suggestions?
There are currently 1981 users online. 1 members and 1980 guests.
