    I have the box, described here:
    as "3/32: (made 09/2017) ZH version Q9377, this time with the designation ZH-01-S912-TVBOX-V.3.0"
    I tried to apply the procedure from
    to the SCV4 and OTA SCV7A.
    that should be possible, right?
    but the process gets stuck on Step 5/5: the Upgrading bar proceeds to the right within ~10 seconds and then stops. No further progress, no messages, no reboot, no nothing.
    I then unplug the box and power it again, and the standard firmware comes up, unchanged. (at least nothing is broken).
    any ideas on what's wrong here?
    Regards
    sthones
      Originally posted by sthones
      Regards
      sthones
      The way i did was like this, i used the burn card method on the pc, after the card was ready i inserted the card on box push the button and power on keep button pushed untill you see the update bar progress, after reboot and then flash like in twrp recovery
      Enviado do meu GT-N8000 através de Tapatalk
        Regards
        sthones
        The update from 4 to 7a is done by recovery you boot to recovery Superceleron already updated the recovery on scv4 to twrp so after you successfuly installed scv4 you boot to recovery and flash scv7a directly, do not unzip the file flash it as is, regards
          so far I did the same, only the upgrading bar runs to the right and nothing happens from there.
          I'm failing on the install of SCAV4 already.
          the recovery that's installing the SCAV4 is included in the SCAV4 img, right? I don't have to install a recovery upfront.
            @ Mandrake,
            Your copy and paste issue is linked to your Chrome version.
            All newer versions seem to have a dependency for touch screens.(?) I can't drag the screen or long-press
            Make sure auto-update is turned off in your Playstore account.
            Try to find Chrome 57.0.2987.132
            Not sure which apk variant.
            Maybe a updated Chrome will work..if you choose a variant that continues to work with our box.
            Please share your results.
              When you hilight something and option legend should popup with the copy, share, and whatever options for you to chose from
              That's the thing. No legends are popping up. On my phone it pops up, but in the box I'm getting nothing.
                Hello
                I'm having problems with my
                3g + 32g + 9377 20170907
                I can not polish
                Which rom should I use?
                please somebody help me
                    Originally posted by ReaperMan View Post
                    @ Mandrake,
                    https://www.apkmirror.com/apk/google...7-132-release/
                    Ok. I'll try to see if that works. I've also seen that the issue is also present in the native browser to comes with SCv7a. It seems long press copy paste functionality is present in other apps though.
                      first id like to thank you for your hard work.
                      so i first installed scv4 on my H96+ pro and was very impressed with the overall performance and image quality.
                      after i updated to scv7 i noticed a change in the image quality, 4k, and even the system UI. i saw you did some change to H265 4k.
                      i tested 4k HDR on sc4 and it was superb. on scv7A not as much.
                      is there anything can be adjusted. seem like lost some contrast in latest firmware.maybe had to to with kernel change.
                      thanks in advance
                        Golani4455
                        Did You check You board before? If yes, than what version of the Box do You have?
                        ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
                          How do I force rgb 10bit? It's missing the menu for that. I need it out else i have issues with green screen on my TV.
                          • superceleron
                            superceleron commented
                            Editing a comment
                            is missing... i need to add it!
                          ZH01-S912-TVBOX-V2.0
                            Is that why I have green screens with 4k movies/streams? Other movies works fine
                              Love this rom. Running this on my h96 pro+ from BangGood. I would love to see an update to Oreo keep up the great work
