Can someone please check if the DTS-HD MA works with this ROM ? With the stock one - it worked perfectly - but now with this ROM and KODI - i tried everything - and i cannot make it work. I ordered two devices - one for a friend - and did not put the rom on it - it is also working.
abel48
Than use TWRP. Cannot say something more about Update app, as I went straight to TWRP, as that way I could make backup od SCV4, prior flashing flashing update, and than flash MAGISK without additional reboots.
I find out what i was doing wrong. I put the extracted files to sdcard then it dont work. But now when i put zip file on it worked in uppdate app. But i dont know if i should choose wipe data and wipe media? I dident do that now...
abel48
Maybe remote config file of Vorke is different than H96's?
You would have to open/mount system from official firmware for Your Box and than look for remote.conf (should be in /system/etc folder). Than copy to Your Box's /system/etc, set permissions, reboot and check again.
RamonSK
I believe it may be wrong mapping. I don't think Android lets You to remap buttons of the connected keyboard, but You could remap (for whole device) Context button as Home one and than it will work
got it. As device is standard i8 I found key172 in standard kl 1997 2433 an change (edit under root) it from MENU to HOME (so now my house is getting me home) also got APP_SWITCH at Win alias key125
Rom is working great im on V7A, i have S32-V6 ddr3 H96 pro+ device. Nova launcher is my main launcher, temperatures are ok.
If i may ask, is there a way to stop autohiding navbar, to stay permament on screen?
