Originally posted by iafilius View PostHi,
Sharing my fanless cooling project- Pry "heatsink" of cpu (with care!)
- Put a nice large hole in cap above cpu
- Make a "heatpipe" to transder heat to outside. (Used copper shims and kafuter k-5204k as thermal glue)
- Use thermal grease, no glue on top for connecting nice large heatsink.
- Put 90x90x18mm heatsink on top.
Didn't connect it permanenty, but first tests just laying the heatsink in top of "heatpipe" showed a about 20 degrees ambient delta (celcius) with a cpu burner test running.
Looking for a slightly bigger heatsink with thick base, and lots of fin's.
Using a smaller heatsink 80x80x7mm results in about 5 degrees higher.
Fyi, while testing, just having the printed circuit on table, there where no components other then cpu which felt hot.
No need to cool anything if cpu heat gets out easy.
Thinking of:- isolating the "heatpipe" preventing heating up the inner part.
- isolating the bottomside heatsink and case, preventing heating up the case/inner parts.
Regards,
Arjan
Originally posted by yudi.15 View PostPlease help me out... I successfully have installed this rom 3 times but everytime when I turn on the device, it stucks itself of the bootloader screen for quite long take it as for 30 minutes and doesn't go any further
I know it is not for this Box but it runs very well on Both my H96Pro Plus Boxes one is a 3gb/16gb ddr3 the other is a 3gb/32gb ddr4.
Originally posted by tht View Post
May i know your H96PRO+ ddr4 coming with which wifi?
I read on Qintex it is AP6330.
Originally posted by oskans View PostSorry error code "[0x30402004]UBOOT/Partition _aml_dtb/Initialize partition/Error result"
by selected option for erase bootloader.
It fail at 4% at first round, then with hope retry again and manage thru. BTW I was flashing using the Qintek 7.1.1 file given in the link above by THT.
I bought an AC Infinity MULTIFAN S1, Quiet 80mm USB Fan from amazon
cut out 80mm opening in the top of the box and then hot glued the fan on to it idle temp now 28 C temp playing 1080p MKv file 32C
heat sink is aluminum 28mm by 8m and the original heatsink stacked on top . also I have padded feet rough 1/8" high under my box extra holes drilled in bottom and sides.
pluged into the usb port is a Dlink usb hub with a SanDisk Ultra Fit 128GB USB 3.0 Flash Drive (SDCZ43-128G-G46) . and the fan running off it . + dongle for Minix Neo A2 lite remote .
You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by wwmoggy; 08 July 2017, 22:30.
Anyone using this Firmware that have not altered their cooling mechanism, please tell me your systems temp at it's peak.
There are currently 2650 users online. 0 members and 2650 guests.
