Did you reformat before adding v6 to the SD card!!?
Hey is there any way I can stop the notification/task bar disappearing automatically! thanks
Originally posted by chenrp View PostAnyone uses different power adapter for this box?where can i find one?
Originally posted by tombraga View Post
I bought this one and i am using it 5A 3V, because i had often power supply problems with box freezing. Working fine
https://www.aliexpress.com/item/1pcs...658181032.html
how did you know that it will fit the plug size...?
i need uk one...
Is the box from gearbest?
i need uk one...
(https://www.aliexpress.com/item/1pcs...660071254.html)
but i bought the us one, so i use an adapter now.
and you buy what you need.
don´t worry about the plugin to tv-box, this fits.
Thanks Celeron for the great roms, already tried 4 different ones this weekend and loving it. I have the rtv box s10, but can't get the remote to work with any of these roms, can you tell me how to replace the map for the remote to work, search everywhere but I can't get it working. Appreciate the good work
i need uk one...
http://www.****.co.uk/itm/AC-DC-5V-3...53.m2749.l2649
Originally posted by wwmoggy View Postreboot works fine here
go into setting / apps / reboot and clear defaults for reboot that might fix it
This has not worked from beginning. After flashing SVC4, I was not able to update to SVC6 with 'Update' app. I had to go to TWRP by pressing little button.
There are currently 1794 users online. 1 members and 1793 guests.
