can you give a link to one that works...I'm afraid to brick the device.
** Just a note Make sure to get newest Beta Magisk 14.2.
V14.0 gave users a lot of issues. no root, bootloop etc.
Originally posted by ReaperMan View Post** Just a note Make sure to get newest Beta Magisk 14.2.
https://forum.xda-developers.com/app...80cb6-t3618589
but i would like to test the new beta 14.2 with the new SCV7 - superceleron !
@ tombrga,
Magisk V.14.0 Installed OK for me.
Looks like I have root and SafetyNet is green and good to go!
Magisk Manager can't autodetect "Boot Image Location" anymore.
I tried adding more modules and updating to newer version....Fail.
Basically indicates a wonky sub-system...waiting for future problems.
Next OTA , when released...in good time, I'll root with Magisk v14.2 or newer.
Originally posted by tombraga View Post
i did not had any issues with magisk 14.0
When it will be done it will be done...
Originally posted by Dodger View PostGreat rom huge improvement over stock. Was wondering how to add / remove favorites on the weos launcher don't have a * key on h96 remote . Been looking to see if this has been asked already but yet to find.
thanks..
Originally posted by chenrp View PostI see gpu overclock..
1.is there an overclock for the gpu?if so,why?
2.is there a way to overclock our cpu?
3. Is there a way to undervoltqe the cpu so we get cooler cpu?
4.i see 64gb versions already... Will this rom fit?
2º no
3º yes if you have root, search for the noFrillsCPU app
4º dunno i have one here but you have to wait for me to test it... i still dint have the time to even unpack it lol...
superceleron what do you think about this http://freaktab.com/forum/tv-player-...919#post674919
Originally posted by almirus View Postsuperceleron what do you think about this http://freaktab.com/forum/tv-player-...919#post674919
Originally posted by mrtt.mattos View Post*@superceleron how i do ota update? help me
@mrtt.mattos @lkbfreak
do you mean an offizial OTA?
this function does not work. in the original rom it does not work, too.
or do you mean the SCV6 OTA?
first flash SCV4, via sc card burner tool and a micro sd card. after starting once, unplug powercord.
(FIRST STEP IS NECCESSARY TO INSTALL TEAM WIN RECOVERY!)
just copy the SCV6 ZIP file on a clean micro sd card, or an usb stick.
with a toothpicker or something llke this, press the button in the hole and connect the power cord.
after 10-20 sec the team win recovery appears, remove the toothpick.
slide to start team win recovery.
enter the first option, INSTALL ROM.
select reading device like sd-card, usb-stick etc.
select the scv6 zip file from the media stick/card.
select option,"reboot after flashing" and then swipe to start.
be patient after flashing. first start may 5 minutesLast edited by DOMin8or; 05 October 2017, 01:41.
There are currently 2543 users online. 0 members and 2543 guests.
