Thanks for the ROM, it has been a good experience so far. I have installed it in my blue PCB LPDDR3 version. I first flashed the SCV4 and then updated through the in-built app to SCV7A , I was actually in the 7.1.2 default ROM that came with the box. I did not check the etase_bootloader box in the Card burner software.
1.My doubt is that, while using other launchers than the default one, I am not able to slect the app with the normal arrow keys in remote and I am made to use the mouse, is there any fix for it?
2.And can we change tge resolution in the Youtube app because I need a HD video and not 4k as my tv is only 1080p?
Waiting for the reply
Originally posted by ripperhack View Posthello, congratulations for your work. I installed the SCV7A version correctly, box 3/32 and it works perfectly. I have a problem, the box works on a 24' pc monitor but no signal appears on a 36' TV. What could be the problem? In the same hdmi tv port another box work correctly
I think it would be strange if the size would be a problem. It's either TV or Box, but both ways it have to be incompatibility.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
superceleron Flashed the new v7 and it works like a charm.. Better then the last one. With the last one I had a green screen with kodi and 4k streams. This one works perfect! All the movies (4k hdr) plays perfect
A while ago someone posted the home launcher with kodi instead of ftmc.. But I can't find it anymore can someone help me in the right direction to find it thanks
Originally posted by devang View Post
You have got same issue as me. Box never reboot, it always power down. Reset button with toothpick should work, press and hold connect power, count 15 and let reset go.
Another way is to power the box from USB OTG cable and do reboot from app. Reboot works for me this way.
There are currently 2249 users online. 1 members and 2248 guests.
