Hi guys, finally i made it. I tried many settings and i succeeded with DTS-HD. I changed the settings in Android for the audio output. I set it to PCM (instead of HDMI or Optical). No logic but happened. Also if i turn on the H96 unit first and then the receiver i do not see the HD-MA and Dolby True HD. First power on the receiver and then the unit. I use HDMI cable instead of optical. Please try this and it should work. Use Kodi 17.6 as FTMC is based on Kodi 16 and it will not work.
Originally posted by simichoil View PostHi guys, finally i made it. I tried many settings and i succeeded with DTS-HD. I changed the settings in Android for the audio output. I set it to PCM (instead of HDMI or Optical). No logic but happened. Also if i turn on the H96 unit first and then the receiver i do not see the HD-MA and Dolby True HD. First power on the receiver and then the unit. I use HDMI cable instead of optical. Please try this and it should work. Use Kodi 17.6 as FTMC is based on Kodi 16 and it will not work.
Originally posted by fatbottom View PostThese files don't play on the superceleron ROM. Need to use the computer instead.
https://ibb.co/mdc2u6
That is normal, they are H264 10bits... this chip dont support hw decode of H264 10bits, the max is can decode correctly is low bitrate 720p 10bits.
Originally posted by fatbottom View Postvideo works under VLC, but it's a bit stuttery and pixelly. Didn't try audio.
Talking of which a few other movies are pixelly, blocky corruption. Some others are fine.
Could it be a buggy video driver in this firmware?
There are currently 2302 users online. 1 members and 2301 guests.
