As for GPU there are devices with S912 and GPU clocked at 600, 650 and 750 MHz. Google says that H96 Pro+ is one with the latter. This Rom has it OCed to 792 MHz.
I think stock freq are 4 x 1 GHz and 4 x 1,5 GHz. Superceleron overclocked weaker cores to 1,5 GHz so now it's more 8 core CPU.
As for GPU there are devices with S912 and GPU clocked at 600, 650 and 750 MHz. Google says that H96 Pro+ is one with the latter. This Rom has it OCed to 792 MHz.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
@ gatsu118,
No, not common. Occasionally after boot-up I will get "android media has stopped"...might be caused by Action Launcher...I've found no work around yet for this.
I wonder if your flash.img is corrupt...I suggest downloading it again...on a different computer...and un-zipping (7-zip and test the archive) or with IZArc or other software....had issues with a zip program in the past.
(Could your USB cable be faulty?)
not sure if its just me, did search and skim read.... but each time i plug in my usb hub (1 > 4 amazon basics usb 2.0) into my box it reboots and same if i unplug (i have green board using this rom and the 4 usb ver ) ps for the record ive got an old psu fan straped to top for use with the OC kernel haha
Still may not be enough. I got reboots when copying files from pendrive when only 2 ports were used (2 of 4 available). Ofc with original charger. So it seems they are hidden coz charger is even not enough for what is officially available. I sould say that for every USB port over this 2 in the Box used You need charger with 400-500 mAh more. Ofc if connected devices doesn't have it's own charger.
SO using all 4 ports of the Box needs around 3,5A charger. 2 ports + 4 port Hub could need even 4,5-5A. Not sure if there are chargers like that. It may be easier to buy Hub with it's own charger.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
superceleron Hey didn't know the best post to find you but I'm kinda freeking out because I can't seem to have smooth playback on kodi (S912), With spmc and amcodec or ftmc I can get it perfect but my build was made for krypton. I tried the latest spmc krypton but subtitles aren't working with amcodec enabled. What do you recommend? Do you know any good Krypton fork with amcodec or should I just make a new build for jarvis... The skin I use isn't available there but wtv.
Thanks for your time!
Well for now i really dont know any good kodi krypton fork... all out there are pure shit... except SPMC, but the problem with spmc is that hes still like a alfa build many stuff still not complete (but is getting there)..
I really need to move on with FTMC krypton, "damn" work that eats all my time... well its life i will get to it when i can!
There are currently 3587 users online. 1 members and 3586 guests.
